Fantastic 4 - Rise of the Silver Surfer
phototex
Post by phototex » Fri Mar 30, 2012 8:21 pm
I searched the forums for errors associated with this disc, and saw that another person had reported the same error, but I never could find a resolution. I get a "Fatal error occurred, program will now exit." on this Blu Ray disc. MakeMKV was "Processing Titles" when the error occurred. Log follows:
Debug log started at Fri Mar 30 20:07:31 2012 , written by MakeMKV v1.7.3 darwin(x86-release)
001005:0000 MakeMKV v1.7.3 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/[snip]/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-875 DA09" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE BE12LU30 4261" opened in DASPI v1.3 mode.
DAFD=ZeNpjYGDgYWBgcGDkZWVhBAIGNAAACgsAaA==
DCE=jfdHBzliB+SbBDP3Vn+5Y2AfqRc+77vRTRzdhKWiBBYpTIRIDxnHXPn4P/tza8Ax2HBu/Vu/FyHoQBDNj86pF+ZewXdTg4bPS1UbTH+F1wLhdpXb7u9I8GNKzvEJwLfgag7lB+FuL6TgimmmSytl4DRPtJwCYtR+Kg==
003317:0000 Loaded 23 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00003.svq
001003:0020 DEBUG: Code 0 at [jcswZ)rOQx@SG{k:29404418
001003:0020 DEBUG: Code 0 at ,`^5-@\:>\]+?f|X-/:29397426
003332:0000 Saved BD+ dump file as /Volumes/Movies 4/dump_FANTASTIC4_2_D7673AB999CE0F33.tgz
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=D7673AB999CE0F3395FBB82CA7C675C8FA46E090
003307:0000 File 00005.m2ts was added as title #0
003307:0000 File 00001.mpls was added as title #1
003025:0000 Title #00004.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00011.mpls was added as title #2
003309:0000 Title 00012.mpls is equal to title 00011.mpls and was skipped
003309:0000 Title 00013.mpls is equal to title 00011.mpls and was skipped
003307:0000 File 00016.mpls was added as title #3
003307:0000 File 00017.mpls was added as title #4
003307:0000 File 00018.mpls was added as title #5
003307:0000 File 00026.mpls was added as title #6
003309:0000 Title 00030.mpls is equal to title 00001.mpls and was skipped
003307:0000 File 00052.mpls was added as title #7
001001:0020 DBG ASSERT: )HXQg"}Y-lC1A6ZjNe^?]X+\: at |b;:Py[lI_@HAv%-d:29399266
Any recommendations would be appreciated. Thanks.
Re: Fantastic 4 - Rise of the Silver Surfer
Post by mike admin » Sat Mar 31, 2012 12:11 pm
phototex wrote: 003332:0000 Saved BD+ dump file as /Volumes/Movies 4/dump_FANTASTIC4_2_D7673AB999CE0F33.tgz
This is a bug in MakeMKV. Please send the tgz dump file referenced above with the link to this topic to support@makemkv.com
phototex
Post by phototex » Mon Apr 02, 2012 9:42 pm
The tgz dump file has been mailed.
LeonF63
Post by LeonF63 » Sat May 12, 2012 1:00 am
I have just today update to version 1.7.4 and am getting the same error at the point.
MakeMKV_log.txt
BD+ dump file attached.
(2 KiB) Downloaded 638 times
reese
Post by reese » Fri May 18, 2012 3:37 am
I also ran in to this. The way I worked arround it was to make a backup on my hard drive with MakeMKV. The button for backup is right next to Open file. Then after that is done I opened the backup file with makemkv and did the rest as if I was backing up another blu-ray disk.
Hope this helps
