Setup: ARM (Automatic Ripping Machine) on Debian, drive on a QNAP QXP-800eS-A1164 HBA (ASM1164, native AHCI/SATA) in a DupliM 7-bay enclosure, previously on USB
Drive history: Bought new in August 2024, sat mostly unused, only started seeing real use in the past month after setting up ARM
Symptom, phase 1 — read timeouts during rips:
The drive reads cleanly through the first 4-5 titles of a multi-title Blu-ray disc, then fails after roughly 35-55 minutes of sustained reading with:
Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT
Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET
This was originally on USB, and I suspected a bridge chip or cabling issue, so I tested extensively:
- Two different USB enclosures (different brands, different bridge chipsets)
- Two different cables
- Two different USB ports/controllers on the host (a standard USB-A port and a USB4 port)
To eliminate USB entirely, I moved the drive to native SATA via a PCIe HBA (ASMedia ASM1164, native AHCI, not SAS/STP). The drive still failed the same way on native SATA. This rules out USB bridge chips, cables, enclosures, and ports as the cause.
I also had a specific UHD disc fail 3 separate times at the identical byte offset (63660029952) with MEDIUM ERROR:L-EC UNCORRECTABLE ERROR on this drive. I suspected a disc defect at first, but I've since successfully ripped that same disc, along with another disc that failed on this drive, on a different drive (a Pioneer BDR-209, cross-flashed to BDR-211M firmware) with no issues. So the discs themselves are fine, this points at the WH16NS40.
Symptom, phase 2 — full link dropout while idle:
More recently, the drive escalated from read timeouts to dropping off the SATA bus completely, and this happened while the drive was idle with no disc loaded, not mid-rip. dmesg shows the kernel's ATA error handler trying progressively slower link speeds to recover it:
ata4.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
ata4: hard resetting link
ata4.00: qc timeout after 15000 msecs (cmd 0xef)
ata4.00: failed to set xfermode (err_mask=0x4)
ata4.00: limiting speed to UDMA/133:PIO3
ata4.00: disable device
$ sudo sg_inq /dev/sr3
sg_inq failed: Transport error
ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata4.00: ATAPI: HL-DT-ST BD-RE WH16NS40, 1.02, max UDMA/133
ata4.00: configured for UDMA/133
- Drive works fine for a while, then throws read timeouts under sustained use (~35-60 min into a rip)
- At some later point, even idle and empty, the kernel's own recovery attempts get triggered and fail (link resets at decreasing speeds, all timing out)
- Kernel gives up and disables the device entirely, unresponsive to even basic SCSI inquiry
- A full power cycle of the enclosure fully recovers it, correct firmware ID, no corruption, MakeMKV sees it fine again
Question:
Has anyone seen this failure pattern on a WH16NS40 before, read timeouts progressing to a full unresponsive lockup that only clears with a power cycle? Is this recoverable (firmware reflash, laser adjustment, etc.) or does it point to a specific failing component? Any diagnostics worth running before I write this drive off?
Happy to provide full dmesg output, MakeMKV debug logs, or anything else useful.
Note: I had Claude (AI) help me write up this post, I have ADHD and writing things out clearly is a struggle for me. All the technical details and troubleshooting are my own.
