Asus BW-16D1HT not reading UHD help please
smithNuggets
Post by smithNuggets »
Like the subject says, my drive isn't reading UHD discs. I've tried about four different UHD discs, and none of them are recognized. Regular Blu-ray discs work fine.
Some background: I purchased the drive refurbished/like new. When it arrived, MakeMKV reported the following:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL1P2B81031
Bus encryption flags: 1F
Highest AACS version: 65
Firmware version: 3.10
For additional information, the sticker on the physical drive shows a different serial number, and it says the drive was manufactured in March 2026. The serial number reported by MakeMKV does not match the one on the sticker. I'm not sure if that's an issue or if the firmware information is simply reporting something different.
From what I understand, everything appears to be set up correctly for UHD, but the drive won't read any UHD discs. Regular Blu-rays work without any issues.
If anyone has any ideas or can help me troubleshoot this, I'd really appreciate it.
I also looked into flashing the drive, but it's already running 3.10, which appears to be the firmware included in the firmware pack (DE_ASUS_BW-16D1HT_3.10_MK.bin). There is also a 3.02 .bin file, but I'm not sure whether downgrading is possible or if doing so could brick the drive.
Re: Asus BW-16D1HT not reading UHD help please
if it was flashed already and was built 2026 its probably a recased old used drive
try cleaning the UHD discs
try cleaning the lasers
not with a laser cleaning disc those are a joke
lg/asus rebrands sn do not match internal sn numbers
pioneers do
smithNuggets
Thanks for the suggestion. I cleaned the lasers and the UHD discs I had and same issue.
