Hi Billycar11,
Can you please help me out as well to get UHD supported for my Verbatim drive.
Device information:
OS device name: M:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.05
Serial number: QCDL095581WL
Firmware date: 2015-11-24
Highest AACS version: 76
Drive platform: RS8510
Firmware version: 1.05
Thank you,
swahl
Pioneer BDR-UD03 UHD possibility
swahl
Re: Pioneer BDR-UD03 UHD possibility
georgesgiralt
Hi !
A friend of mine gave me a Pioneer BDR-UD03FAL from China and I wonder if it is genuine.
Here is what MakeMkv says :
and here is a picture of the label :
If it is genuine, will it will be able to read UHD BD ?
Thanks for the help !
Informations lecteur
Nom du lecteur SE : /dev/sr0
Fabricant : PIONEER
Produit : BD-RW BDR-UD03
Révision : 1.03
Numéro de série : PHDL------WL
Date micrologiciel : 2015-05-14
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 81
Firmware version: 1.03/ID19
sure email me that info andgeorgesgiralt wrote: Wed Sep 02, 2026 4:06 pm Hi !
Here is what MakeMkv says :and here is a picture of the label :Code: Select all
Informations lecteur Nom du lecteur SE : /dev/sr0 Fabricant : PIONEER Produit : BD-RW BDR-UD03 Révision : 1.03 Numéro de série : PHDL------WL Date micrologiciel : 2015-05-14 Marqueurs d'encryptage bus : 1B Version AACS la plus haute : 81 LibreDrive Information Status: Enabled Drive platform: RS8510 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.03/ID19 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
all others email me no need to post your info here publicly just reach out to me directly
see below for email
That's how we get around the no pms
yes flasher sentswahl wrote: Wed Sep 02, 2026 9:51 am Hi Billycar11,
Device information:
OS device name: M:
Revision: 1.05
Thank you,
swahl
swahl
Thanks! Works perfectly
Billycar11 wrote: Thu Sep 03, 2026 1:40 pmyes flasher sentswahl wrote: Wed Sep 02, 2026 9:51 am Hi Billycar11,
Device information:
OS device name: M:
Revision: 1.05
Thank you,
swahl
demrios
I am using a Verbatim 43889 external slim drive and want to enable it as a full LibreDrive / 4K UHD reader.
My current drive info from MakeMKV is as follows:
Revision: 1.14
Serial number: CIDL505536WL
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
Could you please provide me with the correct custom flasher pack and the firmware files for a cross-flash (to UD04) to unlock UHD reading?
Thank you very much for your help!
Revision: 1.14
PM sent.demrios wrote: Sat Sep 05, 2026 1:35 pm Hello,
Revision: 1.14
Sure email me that drive info section see below for emaildemrios wrote: Sat Sep 05, 2026 1:35 pm Hello,
Revision: 1.14
All other no need to post your drive info publicly here just email directly for a faster response so you have to wait for fourm approval
niekonap
Good morning, I have a similar questions to make my drive 4K UHD capable. Below please find my drive information. Your help would be greatly appreciated. The brand of the drive is Verbatim 71094 but its innards are Pioneer. : OS device name: D:
Revision: 1.14
Serial number: BDDL482297WL
Highest AACS version: 82
Revision: 1.14
sure email me that info and all others email me no need to post your info here just reach out to me directlyniekonap wrote: Sun Sep 06, 2026 3:50 pm Good morning, I have a similar questions to make my drive 4K UHD capable. Below please find my drive information. Your help would be greatly appreciated. The brand of the drive is Verbatim 71094 but its innards are Pioneer. : OS device name: D:
Revision: 1.14
see below for email
Mucki75
Hi Coopervid,
I have the same problem with the same drive:
Laufwerksinformation
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.03
Serienummer: PJDL290364WL
Firmware-Datum: 2015-05-14
Highest AACS version: 71
Can you please help me also?
Many thanks in advance!
Top
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.03
Top
sure email me that info and all others email me no need to post your info here just reach out to me directlyMucki75 wrote: Thu Sep 10, 2026 2:55 pm Hi,
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.03
Top
see below for email
matthikins
I also picked up a Pioneer BDR-UD03 recently and would love to make it 4K UHD capable if possible.
OS device name: M:
Revision: 1.03
Serial number: PLDL329761WL
Firmware date: 2015-05-14
Thanks,
matt
OS device name: M:
Revision: 1.03
Thanks,
matt
sure email me that info and all others email me no need to post your info here just reach out to me directlymatthikins wrote: Thu Sep 10, 2026 11:48 pm I also picked up a Pioneer BDR-UD03 recently and would love to make it 4K UHD capable if possible.
OS device name: M:
Revision: 1.03
Thanks,
matt
see below for email
erniee
I just saw that I don't need to post here first
