Main website still down
mkv112
Post by mkv112 » Sun Aug 23, 2026 7:07 pm
www.makemkv.com is still down.. HTTP error 525 is a Cloudflare problem; can't negotiate SSL with the backend server. Either the cert expired or someone changed the site's SSL settings in Cloudflare and broke it.
It probably appears to the admin to be "UP" from the Cloudflare console, but is down for, presumably, the entire world outside of Cloudflare.
For what it's worth, this is coming from USA.
yumadome
Re: Main website still down
Post by yumadome » Sun Aug 23, 2026 11:38 pm
Hi all,
I'm new to MakeMKV. Is there any other source for the program while the main site has an issue? I'm trying to get some disks onto my computer before we go on vacation and I understand this is the best program for that.
yumadome
Post by yumadome » Mon Aug 24, 2026 1:04 am
Hi all, Google finally decided to load a cached version of the site. Most of it didn't work, but it did contain the link to the program download.
If anyone needs it:
https://www.makemkv.com/download/Setup_ ... 1.18.4.exe
I have it up and running, it took the code and I'm off and running. :)
sqadz
Post by sqadz » Mon Aug 24, 2026 1:55 am
yumadome
Post by yumadome » Tue Sep 01, 2026 7:51 am
Thanks Sqadz!
MkeMk8378
Post by MkeMk8378 » Wed Sep 02, 2026 4:27 am
The site is now back up. I just went there a couple of minutes ago. So you should be able to download the newest version of MakeMKV there.
mkv112
Post by mkv112 » Wed Sep 16, 2026 5:33 pm
MkeMk8378 wrote: Wed Sep 02, 2026 4:27 am The site is now back up. I just went there a couple of minutes ago. So you should be able to download the newest version of MakeMKV there.
Thank you!
