I have a Pioneer BDR-UD03, manufacture date on the sticker is 2017, it's in a Vantec enclosure. This is the info from MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.03
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
I've read online that the drive would need to be crossflashed with BDR-UD04 firmware, but it looks to me like MakeMKV is happy to use it as-is for ripping UHD discs, is this correct? or will I see better compatibility crossflashing?
elver wrote: Sat Feb 07, 2026 2:49 pm
Revision: 1.03
Many thanks,
elver
Yes can be made to do UHD email me that drive info section see below for email
Revision: 1.03
Many thanks,
elver
No, it can't read UHD discs until cross-flashed to the BDR-UD04 (UHD model) firmware.
Hi there,
I was wondering if there are still any BDR-UD04 firmware dumps anyone would be willing to share as I was thinking of buying a new old stock BDR-UD03 to rip UHD discs. I was also thinking about the LG BU40N, but lost interest after reading about the jamless playback. I have tried to find a reliable source online which may have a firmware dump, but I haven’t had any luck yet. Thanks in advance.
Kind regards.
ProGT wrote: Tue Sep 01, 2026 2:01 pm
Hi there,
Kind regards.
You just have to email me for the flash kit see below for email
Drive info is required to send the correct kit
Copy and paste it from makemkv
