GOT UHD Collection
wickdguy
GOT UHD Collection
Post by wickdguy »
I'm trying to understand all the different files identified when ripping GOT Season 1 to mkv.
I've ripped the first 2 seasons. When I look at the files generated (I didn't de-select any of the files mkv initially identified) there are multiple copies of Season 1 chapters (see 1st attaached screenshot of files mkv identified before ripping). This doesn't make sense to me. Are there a total of 37 chapters in Season 1. Which of these do I actually need to watch all of Season 1? The listing for Chapters 1-37 is the smallest file size at 496.4 MB vs 29 - 31 GB for the others.
The second screenshot lists the files actually generated after ripping with mkv.
Very confusing . . . (forum won't let me attach the screenshots???)
DC-2187
Re: GOT UHD Collection
Post by DC-2187 »
I'm going to attach a link to this site. this person uploads their collection and has the episodes documented to show which file you need to rip. hope it helps. it saved me alot of trouble especially since i ever seen the show before and I did all of this first before watching.
https://thediscdb.com/series/game-of-thrones-2011
LG-BDNU40
Post by LG-BDNU40 »
Thanks for that link..saved me a heap of guessing and that the 0080x.mpls were correct..so far.
Joi_fan
Post by Joi_fan »
I heard that the disc 3 from GOT can be problematic to rip, sure enough, my discs 3 from season 2 and 3 ends in error. Disc 3 from season 1 worked just fine and I have yet to try the other seasons. So what's the work around this issue?
flojo
Post by flojo »
For 2 discs I had to use a Pioneer BDR-212V.
That said, I exchanged this 3 times. The first time I had 6 discs that wouldn't rip. I exchanged it for a new set and was left with 2 discs. I exchanged it again and was still couldn't rip the same 2 discs. I then exchanged it again and used the Pioneer and successfully ripped the last 2 problematic discs. I'm thinking the Pioneer could have ripped them all the first time, but clearly the discs are pressed very cheaply.
Kevinicus
Post by Kevinicus »
Joi_fan wrote: Sun Jun 28, 2026 12:46 am I heard that the disc 3 from GOT can be problematic to rip, sure enough, my discs 3 from season 2 and 3 ends in error. Disc 3 from season 1 worked just fine and I have yet to try the other seasons. So what's the work around this issue?
Any of the episodes can be problematic. I went through about 5 sets before I was able to complete the series.
Some episodes from 1 set would work fine, but not others. And on other sets, some that worked fine on the first wouldn't, and others that didn't work would.
Right now, I have 2 sets on hand, and I'm still worried if I ever have to redo it, that I won't be able to get them all.
Joi_fan
Post by Joi_fan »
Kevinicus wrote: Sat Aug 29, 2026 8:51 pm
Quick update. I basically ran into issues on 9 episodes total.
Season 2 - Disc 3 - Episodes 7, 8 & 9
Season 3 - Disc 3 - Episode 8
Season 4 - Disc 1 - Episodes 1, 2 & 3
Season 7 - Disc 2 - Episodes 5 & 6
What I did first was to get another BD drive, but that didn't work (At least I got a spare now). So, Instead of buying more expensive drives that may or may not work, I went to a cheaper route and got the 1-7 seasons blu-ray pack for $40 used. The collection won't all be in 4k, but I just don't care at this point. The problem though, the blu-ray episode 6 from season 7 also didn't work, no matter what I did (clean, use different drives, try the file without chapters etc.), nothing worked. So I went and spent even more money today on another season 7 blu-ray ($21 used) just because of Episode 6. This is just driving me insane. I hope when I receive this order, episode 6 will work and I can be done with GoT.
