DVD corrupt or invalid at offset
Desz5
#1 Post by Desz5 » Sat Aug 29, 2026 5:30 pm
I'm trying to rip a DVD to ISO using the the backup function in MakeMKV.
But when loading the ISO into MakeMKV to make .mkv files i get the following errors:
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 86016, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 83968, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 81920, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 79872, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 20480, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 18432, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 16384, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 14336, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 12288, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 10240, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 8192, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 32768, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 30720, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 28672, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 26624, attempting to work around
As seen the DVD loads completely but i'm curious to why i get the error because the DVD is like new.
A Google search results in:
This usually happens due to a dirty or scratched disc, a strange copy-protection scheme, or a read error from your DVD drive.
Clean the disc: Wipe the DVD gently with a soft, lint-free cloth from the center outward, then try again.
Wait and see: If the rip finishes successfully, the data was recovered or bypassed safely, and your video should play fine.Change drives: If the rip fails or freezes, try using a different DVD or Blu-ray drive (such as an internal PC drive instead of a USB mobile drive).
Make a full backup: Instead of direct ripping, try doing a full disc backup first in MakeMKV, then open that backup folder to extract your movie file
I've tried cleaning it and use a different DVD Drive, but i got the same result
I have this DVD (Batman & Mr.Freeze: SubZero) multiple times so i tried ripping it with different discs.
But with all the discs i get the exact same results at the same offsets.
I've tried a different DVD (The Batman Superman Movie) and got a similar error corrupt or invalid at offset...
Used a different DVD and again corrupt or invalid at offset, at the exact same spot.
Now i don't think the discs are all scratched or dirty at the exact same spot, but what could this be?
Could it be a strange copy-protection scheme?
simonsteph
Re: DVD corrupt or invalid at offset
#2 Post by simonsteph » Wed Nov 11, 2026 7:07 pm
I have only come across this type of error once with 'Sting- Accousta' Music DVD.
What I did was to backup the whole DVD to a ISO file using MakeMKV and then use MKVToolNix to create the MKV file
It could a strange copy-protection as you suggested but I also find it strange that you have more than one disc with this type of error.
Try the above first to see if that helps
