Pioneer bdr 209 and Pioneer bdr 209m
Re: Pioneer bdr 209 and Pioneer bdr 209m
MelonIon wrote: Wed Jul 15, 2026 11:51 pm hey, i got a bdr-209m on a tri-boot mac pro 5,1.
the drive works well and plays blu-rays (not uhds) efficiently on both
macos with the macgo bluray player and win10 with the makemkv+vlc workaround,
however, i havent managed to make it work on ubuntu.
was wondering of the functionalities gained by flashing the drive with your fw packages
and if it would retain full compatibility with the oses (id appreciate some help with the ubuntu situation)
and finally, your recommendations regarding bluray/uhd player/bdxl burner apps for all oses.
thanks!
Sure email me your makemkv drive info section see below for email
only benefit to the fw is it will also do UHD the rest is all just config for having makemkv integration on linux work
titanofwar
Post by titanofwar »
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
Firmware date: 2017-12-21
Drive platform: RS8601
Firmware version: E114/ID71
Does this drive support UHD ? if so will i be able to do the firmware change on Linux ?
titanofwar wrote: Sun Jul 19, 2026 12:21 am Drive Information
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number:
no need to post your info publicly just email me directly
see below for email
flasher is windows only but you can use a vm
works on linux after flashing
jonbitzen
Post by jonbitzen »
Is there a way to cross-flash my drive to be able to read UHD discs? I have the following info from MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.31
Serial number:
Firmware date: 2015-05-25
Drive platform: RS8600
Firmware version: 1.31
jonbitzen wrote: Fri Aug 28, 2026 7:59 pm Is there a way to cross-flash my drive to be able to read UHD discs? I have the following info from MakeMKV:
Revision: 1.31
Serial number:
PM sent.
Revision: 1.31
Serial number:
see below for email
kraath
Post by kraath »
Well I got a few of these fullsize 5,25. On official firmware they can`t do 4k.
Can you really just flash them to enable that mode?
OS device name: H:
Current profile: CD-ROM
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: nope
Firmware date: 2018-05-08
Bus encryption flags: 13
Highest AACS version: 64
Firmware version: 1.51/ID61
kraath wrote: Sat Sep 05, 2026 4:49 pm Well I got a few of these fullsize 5,25. On official firmware they can`t do 4k.
OS device name: H:
Revision: 1.51
Serial number: nope
PM sent.This is for 8600only. 8601 needs diffrent firmware.
OS device name: H:
Revision: 1.51
Serial number: nope
Sure email me that drive info section see below for email
All other no need to post your drive info publicly here just email directly for a faster response so you have to wait for fourm approval
fjjwfp
Post by fjjwfp »
Hi all, I have a BDR209 with the following info, can someone help with flashing it to enable 4k reading please? Thank you very much!
OS device name: G:
Revision: 1.51
Serial number:
Highest AACS version: 82
Firmware version: 1.51/ID60
fjjwfp wrote: Fri Sep 11, 2026 2:46 pm Hi all, I have a BDR209 with the following info, can someone help with flashing it to enable 4k reading please? Thank you very much!
OS device name: G:
Revision: 1.51
Serial number:
PM sent.
OS device name: G:
Revision: 1.51
Serial number:
Franklynn
Post by Franklynn »
@Coopervid
I was hoping you could help me restore my Pioneer BDR-S09JBK to its original firmware.
The drive originally had BDR-S09 1.50 / RS8600 / ID43 firmware. It was crossflashed first to BDR-211M 1.53 / RS8800 / ID60, and then to BDR-S11JX 1.53 / RS8800 / ID72.
The crossflashes enabled UHD reading, but unfortunately UHD functionality is only partial. Even after carefully cleaning the optical pickup several times, only 4 of the 7 UHD discs I tested are readable. The same discs behave essentially the same with both the 211M and S11JX firmware. I suspect the Blu-ray optical pickup/405 nm laser may be becoming marginal. I realize this may not necessarily be the laser diode itself, but it appears that the Blu-ray optical system has reduced read margin. I plan to use my other pioneer and LG drives for UHD instead as all my 4k blu-rays are perfectly readable on them.
More importantly, I discovered that RealTime PureRead worked much better with the original S09 firmware. I have a badly damaged audio CD that normally skips badly. With the original S09 firmware and RealTime PureRead, it played almost perfectly. With the 211M firmware, RealTime PureRead was unavailable, and with the S11JX firmware the PureRead/RealTime options appear in the Pioneer utility, but the damaged CD still plays very poorly.
Since the UHD functionality on this particular drive is limited anyway, I would rather restore it to its original BDR-S09 1.50 / RS8600 / ID43 firmware and continue using it primarily for its excellent PureRead performance with audio CDs.
I saw that you have previously helped S09/209 owners obtain original firmware for returning to stock. Would you be able to send me the correct files and flashing method to safely restore mine?
Franklynn wrote: Fri Sep 18, 2026 4:28 am
flasher sent
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Franklynn wrote: Fri Sep 18, 2026 4:28 am @Coopervid
Do you still ned help since Billy wrote "flasher sent"?
