tl;dr; I think my drive should be able to handle UHD, and some of the documentation seems to say I can, but I can't. I may be mis-reading the steps. I was going to use Omni tool, which seems to need my original firmware.
Trying to get my original firmware, using sdftool, it lists my drive:
sdftool -l
Found 1 drives(s)
00: \Device\CdRom0, \Device\CdRom0, F:
HL-DT-ST_BDDVDRW_UH12NS40_1.00_211602231042_SIK92G76G182
But trying to read to a bin file, I get:
sdftool -d \Device\CdRom0 -f UH12NS40_1.00.bin
Unable to load sdf.bin
Internal error 0xffffffff
Running MKV 1.18.4 (win x64) I see my drive as
Manuf: HL-DT-ST
Prod: BDDVDRW UH12NS40
Rev: 1.00
Firmware date: 2116-02-23 10:42
Bus encrypt: 16
LibreDrive
Drive platform MT1959
Firmware version: 1.00
(I Can provide more info if needed.)
LG HL-DT-ST UH12NS40 flashing issues
Re: LG HL-DT-ST UH12NS40 flashing issues
have you opened/run a disc through makemkv yet so it download the sdf?mkenyon2 wrote: Wed Aug 26, 2026 12:14 am tl;dr; I think my drive should be able to handle UHD, and some of the documentation seems to say I can, but I can't. I may be mis-reading the steps. I was going to use Omni tool, which seems to need my original firmware.
sdftool -l
Found 1 drives(s)
Manuf: HL-DT-ST
Rev: 1.00
Bus encrypt: 16
LibreDrive
mkenyon2
I made MKV files off of a Blu-ray and a DVD, with MakeMKV running as admin. Still no sdf.bin file in C:\Program Files (x86)\MakeMKV
Sayaka
I am not surprised that this is not working.mkenyon2 wrote: Wed Aug 26, 2026 12:14 am tl;dr; I think my drive should be able to handle UHD, and some of the documentation seems to say I can, but I can't. I may be mis-reading the steps. I was going to use Omni tool, which seems to need my original firmware.
sdftool -l
Found 1 drives(s)
Manuf: HL-DT-ST
Rev: 1.00
Bus encrypt: 16
LibreDrive
This :
sdftool -d \Device\CdRom0 -f UH12NS40_1.00.binIf you want to try to make a backup of your firmware for whatever reason, try this instead (inside the folder where MakeMKV was installed) :
.\sdftool64.exe -d F: dump fullIf you want to make your drive UHD-compatible :
.\sdftool64.exe -d F: rawflash main -i "C:\replace-this-with-the-correct-path-to-the-following-firmware-file\DE_LG_WH16NS60_1.02_MK.bin"-
Sayaka
I've just fixed a typo and replaced the "F:\replace-this[...]" part with "C:\replace-this[...]" since 1) the letter of your main HDD or SDD partition will be different from F: since that's the drive letter for your optical drive and 2) the letter of your main HDD or SDD partition is likely to be C:
My apologies for the typo.
