LG HL-DT-ST UH12NS40 flashing issues
mkenyon2
Post by mkenyon2 »
tl;dr; I think my drive should be able to handle UHD, and some of the documentation seems to say I can, but I can't. I may be mis-reading the steps. I was going to use Omni tool, which seems to need my original firmware.
Trying to get my original firmware, using sdftool, it lists my drive:
sdftool -l
Found 1 drives(s)
00: \Device\CdRom0, \Device\CdRom0, F:
HL-DT-ST_BDDVDRW_UH12NS40_1.00_211602231042_SIK92G76G182
But trying to read to a bin file, I get:
sdftool -d \Device\CdRom0 -f UH12NS40_1.00.bin
Unable to load sdf.bin
Internal error 0xffffffff
Running MKV 1.18.4 (win x64) I see my drive as
Manuf: HL-DT-ST
Prod: BDDVDRW UH12NS40
Rev: 1.00
Firmware date: 2116-02-23 10:42
Bus encrypt: 16
LibreDrive
Drive platform MT1959
Firmware version: 1.00
(I Can provide more info if needed.)
Re: LG HL-DT-ST UH12NS40 flashing issues
mkenyon2 wrote: Wed Aug 26, 2026 12:14 am tl;dr; I think my drive should be able to handle UHD, and some of the documentation seems to say I can, but I can't. I may be mis-reading the steps. I was going to use Omni tool, which seems to need my original firmware.
sdftool -l
Found 1 drives(s)
Manuf: HL-DT-ST
Rev: 1.00
Bus encrypt: 16
LibreDrive
have you opened/run a disc through makemkv yet so it download the sdf?
mkenyon2
Post by mkenyon2 »
I made MKV files off of a Blu-ray and a DVD, with MakeMKV running as admin. Still no sdf.bin file in C:\Program Files (x86)\MakeMKV
Sayaka
Post by Sayaka »
sdftool -l
Found 1 drives(s)
Manuf: HL-DT-ST
Rev: 1.00
Bus encrypt: 16
LibreDrive
I am not surprised that this is not working.
This :
Cannot possibly work. You are not even specifying an actual command for sdftool to use (and you are not using -f correctly).
If you want to try to make a backup of your firmware for whatever reason, try this instead (inside the folder where MakeMKV was installed) :
.\sdftool64.exe -d F: dump full
If you get an error (and sometimes you may get an error even if the firmware is not encrypted, and it shouldn't be encrypted in this case), it means there is no easy way to dump the full firmware.
If you want to make your drive UHD-compatible :
.\sdftool64.exe -d F: rawflash main -i "C:\replace-this-with-the-correct-path-to-the-following-firmware-file\DE_LG_WH16NS60_1.02_MK.bin"
You can find DE_LG_WH16NS60_1.02_MK.bin inside MartyMcNuts' All You Need Firmware Pack, it can be downloaded from one of the links in this thread : viewtopic.php?t=22896
Sayaka
Post by Sayaka »
I've just fixed a typo and replaced the "F:\replace-this[...]" part with "C:\replace-this[...]" since 1) the letter of your main HDD or SDD partition will be different from F: since that's the drive letter for your optical drive and 2) the letter of your main HDD or SDD partition is likely to be C:
My apologies for the typo.
