Public KeyDB Disc Submissions
allenpeak
Post by allenpeak »
Disc type: UHD
Disc ID: 44F6D7CB148774EC65B9890E71E8F8CF0E18A50E
Disc dump filename: MKB20_v82_Avatar-_Fire_and_Ash_7728
Drive: BD-RE BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private browsing? Yes
MKB_RO.inf link: https://u.pcloud.link/publink/show?code ... Fvs5m6vypX
Disc dump link: https://u.pcloud.link/publink/show?code ... Fvs5m6vypX
keydb_helper
Post by keydb_helper »
allenpeak wrote: Mon Aug 24, 2026 3:08 am Disc type: UHD
Thanks for the submission allenpeak but your disc was added to the public keydb on May 19.
Your log indicates a transient failure occurred whilst MakeMKV was trying to activate LibreDrive. Power down your drive completely, reboot your PC, make sure the keydb is in the correct location and you should be good to go.
KeyDB Download
el_vandragon
Post by el_vandragon »
Disc type: UHD
Disc ID: 0x0B9D93E4FFF32BFADE58CD8FFEF97C43F4E64551
Disc dump filename: MKB20_v82_BACKROOMS_CA6E.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.02 (OmniDrive)
Did you sync the public keydb within the last 15 minutes? Yes (AACS keydb.cfg file created on 2026.08.24 18:17:01)
Folder with Both Files Link: https://drive.google.com/drive/folders/ ... drive_link
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/18Sf3MH ... drive_link
Disc dump link: https://drive.google.com/file/d/1Ub32O_ ... drive_link
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_Center_Stage_B094
MKB20_v77_Chinatown_244B
*MKB20_v82_BACKROOMS_CA6E
el_vandragon wrote: Tue Aug 25, 2026 1:36 am Did you sync the public keydb within the last 15 minutes? Yes (AACS keydb.cfg file created on 2026.08.24 18:17:01)
Thanks for the very comprehensive submission el_vandragon but don't stress too much about the timestamp. It is an honour system after all and I don't want folks to effectively reveal their time zone when posting here.
KeyDB Download
subspet
Post by subspet »
Disc type: BD-ROM
Disc ID: af2f4afbf28156138d323638ed2c520732b679df
Disc dump filename: MKB_v82_Monster_-_Box_1_Disc_1_1E0A.tgz
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link: https://drive.google.com/file/d/1R2Y5gd ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1leakD- ... sp=sharing
Disc type: BD-ROM
Disc ID: 514b5f9e9acfba969dbd6626199a969b1e334797
Disc dump filename: MKB_v82_Monster_-_Box_1_Disc_2_5CB8.tgz
Drive: BW-16D1HT
MKB_RO.inf link: https://drive.google.com/file/d/1Qu9Mob ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1WQNFfJ ... sp=sharing
Disc type: BD-ROM
Disc ID: e57fbd372acf5251d9a4b6a1fa6046ebe1951cd3
Disc dump filename: MKB_v82_Monster_-_Box_1_Disc_3_B462.tgz
Drive: BW-16D1HT
MKB_RO.inf link: https://drive.google.com/file/d/1XBwgi8 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1oCsXnF ... sp=sharing
frameloose
Post by frameloose »
I have a question i don't seem to find the solution for.
I have added two discs with FindVUK (with dvdfab), and they are present in my keydb.cfg in .MakeMKV-folder for my user.
The last one I added today was 0x75954CFCBC4EFB24CA8721C67FAC8ABEEFF2F289
But MakeMKV can't seem to find the key and use it, so get that the volume key is unknown. (yes, i have restarted MakeMKV)
My ISP have blocked MakeMKVs "key server", so I'm only using keydb.
For reference I'm in the middle of ripping Stranger Things, so MakeMKV utilizes(?) they keydb file.
When running Validate through keydb_helper it checks out, and verifies that the correct key is in the file: KEYDB: Identical entry already present in keydb-file
caseablee
Post by caseablee »
frameloose wrote: Tue Aug 25, 2026 5:41 pm I have a question i don't seem to find the solution for.
Which disks are you having issues with for Stranger Things? There were a couple (Season 2 Disc 2, Season 4 Disc 3, Season 5 Disc 2) that were not encrypted so you need to backup the disk and then delete the aacs folder before throwing it back into MakeMKV to process. See here for more.
Persevere8495
Post by Persevere8495 »
Disc type: Blu-ray
Drive: HL-DT-ST BD-RE WH16NS40
Drive firmware: 3.10 (Patched Microcode Access Re-Enabled)
LibreDrive status: Enabled (v06.3)
--- DISC 1 ---
Disc ID: AF2F4AFBF28156138D323638ED2C520732B679DF
Disc dump filename: MKB_v82_MONSTER_S1D1_1E0A.tgz
--- DISC 2 ---
Disc ID: 514B5F9E9ACFBA969DBD6626199A969B1E334797
Disc dump filename: MKB_v82_MONSTER_S1D2_5CB8.tgz
--- DISC 3 ---
Disc ID: E57FBD372ACF5251D9A4B6A1FA6046EBE1951CD3
Disc dump filename: MKB_v82_MONSTER_S1D3_B462.tgz
All files are on Mega: https://mega.nz/folder/vjZTFJIR#PVONM_EI4ZTqmk1GxbRpBQ
Post by SamuriHL »
MakeMKV only uses the VUK from the keydb.cfg, which is not what you find with FindVUK for UHD's....only the unit keys. That is why it doesn't work for MakeMKV.
saltshaker
Post by saltshaker »
Disc type: Blu-ray
Disc ID: 9b568ff10abcea5ecac06cf0767b199946339618
Disc dump filename: MKB_v82_Roselia_10th_Anniversary_Best_Album「Lehre_der_Rose」【Blu-ray付生産限定盤】DISC1_91DC
Drive: BDDVDRW CP40NG10
Drive firmware: 1.00
MKB_RO.inf link: https://drive.google.com/file/d/14XrV1Z ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1x3na5p ... sp=sharing
Thank you!
frameloose
SamuriHL wrote: Tue Aug 25, 2026 10:13 pm MakeMKV only uses the VUK from the keydb.cfg, which is not what you find with FindVUK for UHD's....only the unit keys. That is why it doesn't work for MakeMKV.
Aha. So I just have to continue supply dumps here, nothing available for us "end users" to help out with the VUK?
Post by SamuriHL »
frameloose wrote: Wed Aug 26, 2026 3:03 pm Aha. So I just have to continue supply dumps here, nothing available for us "end users" to help out with the VUK?
Correct.
seaurchin
Post by seaurchin »
Hatchet
Disc type: UHD
Disc ID: 7F5C888AC87B7D15D04457B6C3FD145012E04B1D
Disc dump filename: MKB20_v82_HATCHET_1_CBDA.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
MKB_RO.inf link: https://drive.google.com/file/d/13BOJ72 ... drive_link
Disc dump link: https://drive.google.com/file/d/158bG3b ... drive_link
Hatchet II
Disc type: UHD
Disc ID: AB768812AA62C60D7574B1C104CD3EF662459DA3
Disc dump filename: MKB20_v82_HATCHET_2_44D8.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1PAxSvR ... drive_link
Disc dump link: https://drive.google.com/file/d/1c5c7XK ... drive_link
Hatchet III
Disc type: UHD
Disc ID: B135970415F528FB1C3795D170922F04EE50593D
Disc dump filename: MKB20_v82_HATCHET_3_C034.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1WNwbo7 ... drive_link
Disc dump link: https://drive.google.com/file/d/15z7xxM ... drive_link
Victor Crowley
Disc type: UHD
Disc ID: 952E78518FE2B13A76B35928C514EFB820663E88
Disc dump filename: MKB20_v82_VICTOR_CROWLEY_HATCHET_4_6AE2.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1pAh-gB ... drive_link
Disc dump link: https://drive.google.com/file/d/1w_Lg8s ... drive_link
Nocobo
Post by Nocobo »
Disc type: UHD
Disc ID: 0x0EF0413101E1CB8983294445D0856722926677ED
Disc dump filename: MKB20_v82_Auntie_Mame_-_4K_UHD_B03A.tgz
Drive: WH14NS40 (Flashed WH16NS60)
MKB_RO.inf link: https://drive.google.com/file/d/1wE-72w ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1ejw49F ... sp=sharing
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following BD and UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB_v82_Roselia_10th_Anniversary_Best_Album「Lehre_der_Rose」【Blu-ray付生産限定盤】DISC1_91DC
*MKB20_v82_Auntie_Mame_-_4K_UHD_B03A
*MKB20_v82_Billy_Liar_06AC
*MKB20_v82_HATCHET_1_CBDA
*MKB20_v82_HATCHET_2_44D8
*MKB20_v82_HATCHET_3_C034
*MKB20_v82_Obsession_C632
*MKB20_v82_Pinocchio_Unstrung_97AC
*MKB20_v82_Practical_Magic_9B1E
*MKB20_v82_VICTOR_CROWLEY_HATCHET_4_6AE2
I believe all other valid submissions have also been processed.
KeyDB Download
