Public KeyDB Disc Submissions
mczocker32
Post by mczocker32 » Sat Aug 22, 2026 8:08 pm
Disc type: UHD
Disc ID: 0xAAD3224522D19E76AE2577BC5D4946DEAB78A7B4
Disc dump filename: MKB20_v82_KINDERGARTEN_COP_682E.tgz
Drive: HL-DT-ST BD-RE WH16NS40
Drive firmware: 1.05
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1lcpYkI ... drive_link
Disc dump link: https://drive.google.com/file/d/1DnEKKr ... drive_link
AkWreckDiver
Post by AkWreckDiver » Sat Aug 22, 2026 11:30 pm
Disc type: UHD
Disc ID: 254E18816B92CC877F24669167326A53423E3232
Disc dump filename: MKB20_v82_Sinners_6E91
Drive: HL-DT-ST
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.dropbox.com/scl/fi/6wr0ozia ... wegr5&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/2c053y3d ... il0w9&dl=0
keydb_helper
Post by keydb_helper » Sun Aug 23, 2026 1:47 am
Vidmusic wrote: Sat Aug 22, 2026 5:43 am Disc type: BD-ROM
Disc ID: 1bd8f9c33736932bdf448eece42fa3936a9f5988
Disc dump filename: MKB_v82_Dragon_Ball_DAIMA_D3_9B44
mczocker32 wrote: Sat Aug 22, 2026 8:08 pm Disc type: UHD
AkWreckDiver wrote: Sat Aug 22, 2026 11:30 pm Disc type: UHD
Thank you all for following the submission template and including the required files. All three discs have been added to the public keydb.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
chucky527c
Post by chucky527c » Sun Aug 23, 2026 9:42 pm
The Saint 4K UHD (Steelbook) (US)
Disc type: UHD
Disc ID: 16cf19e990cbf5a1650b514e41c804f24fa62ce6
Disc dump filename: MKB20_v82_The_Saint_24F9
Drive: BD-RE WH16NS60
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1s7MXqJ ... drive_link
Disc dump link: https://drive.google.com/file/d/1tGIGAH ... drive_link
chucky527c
Post by chucky527c » Sun Aug 23, 2026 9:49 pm
Enemy at the Gates 4K UHD (Steelbook) (US)
Disc type: UHD
Disc ID: 18c8bf5ad123bb78c34fc554917887f61b9dabe3
Disc dump filename: MKB20_v82_Enemy_At_The_Gates_DE65.tgz
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1hHd7Iq ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1UAzVH- ... sp=sharing
keydb_helper
Post by keydb_helper » Mon Aug 24, 2026 12:55 am
chucky527c wrote: Sun Aug 23, 2026 9:42 pm Disc ID: 16cf19e990cbf5a1650b514e41c804f24fa62ce6
chucky527c wrote: Sun Aug 23, 2026 9:49 pm Disc ID: 18c8bf5ad123bb78c34fc554917887f61b9dabe3
Thanks for the submission chucky527c but both of your discs were added to the keydb roughly 24 hours before your post. If you are using SamuriHL's KeyDB Assistant tool and it indicates that the media key, volume ID, VUK, and unit keys are present you don't need to post anything to this thread.
If you were searching for your discs in the public keydb the correct disc ID for The Saint is 0xD589AADC222C33025AE1285D0D21F6BAFC1F7354 and Enemy at the Gates is 0x2AFC72BD4B5A69B6D94E1A60B25402D82CE17B22. The process for generating these disc ID values is outlined in the opening post of this thread.
KeyDB Priority List
chucky527c
Post by chucky527c » Mon Aug 24, 2026 1:13 am
keydb_helper wrote: Mon Aug 24, 2026 12:55 am
Sorry for the unnecessary work. Even though I've done this many times before, this time I made a mistake.
keydb_helper
Post by keydb_helper » Mon Aug 24, 2026 1:18 am
chucky527c wrote: Mon Aug 24, 2026 1:13 am Sorry for the unnecessary work. Even though I've done this many times before, this time I made a mistake.
No worries mate
KeyDB Priority List
allenpeak
Post by allenpeak » Mon Aug 24, 2026 3:08 am
Disc type: UHD
Disc ID: 44F6D7CB148774EC65B9890E71E8F8CF0E18A50E
Disc dump filename: MKB20_v82_Avatar-_Fire_and_Ash_7728
Drive: BD-RE BP60NB10
MKB_RO.inf link: https://u.pcloud.link/publink/show?code ... Fvs5m6vypX
Disc dump link: https://u.pcloud.link/publink/show?code ... Fvs5m6vypX
keydb_helper
Post by keydb_helper » Mon Aug 24, 2026 4:35 am
allenpeak wrote: Mon Aug 24, 2026 3:08 am Disc type: UHD
Thanks for the submission allenpeak but your disc was added to the public keydb on May 19.
Your log indicates a transient failure occurred whilst MakeMKV was trying to activate LibreDrive. Power down your drive completely, reboot your PC, make sure the keydb is in the correct location and you should be good to go.
KeyDB Priority List
el_vandragon
Post by el_vandragon » Tue Aug 25, 2026 1:36 am
Disc type: UHD
Disc ID: 0x0B9D93E4FFF32BFADE58CD8FFEF97C43F4E64551
Disc dump filename: MKB20_v82_BACKROOMS_CA6E.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.02 (OmniDrive)
Did you sync the public keydb within the last 15 minutes? Yes (AACS keydb.cfg file created on 2026.08.24 18:17:01)
Folder with Both Files Link: https://drive.google.com/drive/folders/ ... drive_link
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/18Sf3MH ... drive_link
Disc dump link: https://drive.google.com/file/d/1Ub32O_ ... drive_link
keydb_helper
Post by keydb_helper » Tue Aug 25, 2026 3:41 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_Center_Stage_B094
MKB20_v77_Chinatown_244B
*MKB20_v82_BACKROOMS_CA6E
el_vandragon wrote: Tue Aug 25, 2026 1:36 am Did you sync the public keydb within the last 15 minutes? Yes (AACS keydb.cfg file created on 2026.08.24 18:17:01)
Thanks for the very comprehensive submission el_vandragon but don't stress too much about the timestamp. It is an honour system after all and I don't want folks to effectively reveal their time zone when posting here.
KeyDB Priority List
subspet
Post by subspet » Tue Aug 25, 2026 4:11 pm
Disc type: BD-ROM
Disc ID: af2f4afbf28156138d323638ed2c520732b679df
Disc dump filename: MKB_v82_Monster_-_Box_1_Disc_1_1E0A.tgz
Drive: BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link: https://drive.google.com/file/d/1R2Y5gd ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1leakD- ... sp=sharing
Disc type: BD-ROM
Disc ID: 514b5f9e9acfba969dbd6626199a969b1e334797
Disc dump filename: MKB_v82_Monster_-_Box_1_Disc_2_5CB8.tgz
Drive: BW-16D1HT
MKB_RO.inf link: https://drive.google.com/file/d/1Qu9Mob ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1WQNFfJ ... sp=sharing
Disc type: BD-ROM
Disc ID: e57fbd372acf5251d9a4b6a1fa6046ebe1951cd3
Disc dump filename: MKB_v82_Monster_-_Box_1_Disc_3_B462.tgz
Drive: BW-16D1HT
MKB_RO.inf link: https://drive.google.com/file/d/1XBwgi8 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1oCsXnF ... sp=sharing
frameloose
Post by frameloose » Tue Aug 25, 2026 5:41 pm
I have a question i don't seem to find the solution for.
I have added two discs with FindVUK (with dvdfab), and they are present in my keydb.cfg in .MakeMKV-folder for my user.
The last one I added today was 0x75954CFCBC4EFB24CA8721C67FAC8ABEEFF2F289
But MakeMKV can't seem to find the key and use it, so get that the volume key is unknown. (yes, i have restarted MakeMKV)
My ISP have blocked MakeMKVs "key server", so I'm only using keydb.
For reference I'm in the middle of ripping Stranger Things, so MakeMKV utilizes(?) they keydb file.
When running Validate through keydb_helper it checks out, and verifies that the correct key is in the file: KEYDB: Identical entry already present in keydb-file
caseablee
Post by caseablee » Tue Aug 25, 2026 8:58 pm
frameloose wrote: Tue Aug 25, 2026 5:41 pm I have a question i don't seem to find the solution for.
Which disks are you having issues with for Stranger Things? There were a couple (Season 2 Disc 2, Season 4 Disc 3, Season 5 Disc 2) that were not encrypted so you need to backup the disk and then delete the aacs folder before throwing it back into MakeMKV to process. See here for more.
