lilbit
Post by lilbit »
Has anyone bought one of the new batch that’s appearing around the net ? If so are they flash able ?
asusMKV
Post by asusMKV »
need help for downgrade. its possible for my firmare?
Laufwerksinformation
OS-Gerätename: G:
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E102
Serienummer: CLDL285507WL
Firmware-Datum: 2023-04-20
Highest AACS version: 82
Drive platform: RS8511
Firmware version: E102/ID26
asusMKV wrote: Sun Aug 23, 2026 8:08 am need help for downgrade. its possible for my firmare?
OS-Gerätename: G:
Produzent: ASUS
Revision: E102
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
OS-Gerätename: G:
Produzent: ASUS
Revision: E102
PM sent.
asusMKV
Post by asusMKV »
OS-Gerätename: G:
Produzent: ASUS
Revision: E102
doesnt work ... but i changed the mode of the drive to "normal mode". now the original fw was deleted ...
asusMKV wrote: Sun Aug 23, 2026 7:01 pm
Coopervid wrote: Sun Aug 23, 2026 3:18 pm
OS-Gerätename: G:
Produzent: ASUS
Revision: E102
PM sent.
Email me I may be able to recover your drive after you were sent an unsafe unlocked flasher.
This is why it's important for everyone to use my auto flasher it has safeguards built in so this does not happen.
Billycar11 wrote: Sun Aug 23, 2026 11:05 pm
PM sent.
Don't post bullshit. This drive is too new and it isn't borked. It just can't be flashed. What I oversaw is that the firmware is too new. It will still work as a BD drive just fine and even you can't flash it for UHD. So stop to unsettle people.
Coopervid wrote: Mon Aug 24, 2026 7:03 pm Don't post bullshit. This drive is too new and it isn't borked. It just can't be flashed. What I oversaw is that the firmware is too new. It will still work as a BD drive just fine and even you can't flash it for UHD. So stop to unsettle people.
You very much can put a drive into a softbricked state by force flashing old fw.
It's part of the way I do 12/22+ cross flashing
Billycar11 wrote: Mon Aug 24, 2026 9:51 pm
Still bullshit and you want to unsettle people. As I said:You can't flash these type of drives and there was no harm to this drive.
Coopervid wrote: Mon Aug 24, 2026 9:56 pm
When I flash a 12/22+ pioneer drive using the unlocked flasher
To old fw it will be in a soft bricked state
And it will say it failed to return to normal mode.
After that the way to get it out of the softbricked state is to use the official pioneer updater
But now in this case there is none for the ud03
Especially for 12/22+
skyrider
Post by skyrider »
After putting the drive into kernel mode, you can reflash the same (latest) firmware again using the official Pioneer flasher from their website.
This works because once the drive is in kernel mode, it is detected as firmware version 0000 with a date of 00/00/00, so the procedure that determines whether the currently installed firmware is older, newer, or the same will always report to the flasher that the firmware is older, and therefore allow flashing.
While in kernel mode, you cannot flash an older kernel & firmware using the official flasher, because even though the procedure will start, the Pioneer flasher will return the error "failed to update the kernel part".
I would like to know whether the original Pioneer flasher is capable of performing a recovery on a drive that has a damaged kernel / firmware.
Will the official flasher be able to detect the drive in such a situation?
Looking for a Pioneer 4K UHD drive?
Click here
skyrider wrote: Mon Aug 24, 2026 11:50 pm After putting the drive into kernel mode, you can reflash the same (latest) firmware again using the official Pioneer flasher from their website.
Yes but where can you get an official ud03 flasher?
That's 12/22+
That's why I was curious to test if my auto flasher will recover it
skyrider
Post by skyrider »
Billycar11 wrote: Tue Aug 25, 2026 1:31 am
That's 12/22+
mail sent
Click here
vinicsb96
Post by vinicsb96 »
Hi! I have an ASUS SBW-06D5H-U with the following LibreDrive information:
Firmware version: E101/ID26
Firmware date: 2018-08-22
LibreDrive: Enabled
I would like to crossflash it to make it UHD-friendly. Could you please let me know if the required flasher/firmware is available for this exact drive?
Thank you!
vinicsb96 wrote: Mon Aug 31, 2026 6:15 pm Hi! I have an ASUS SBW-06D5H-U with the following LibreDrive information:
LibreDrive: Enabled
Thank you!
PM sent.
