aduma wrote: Sun Jul 26, 2026 4:15 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
Serial number: <redacted>
Firmware date: 2018-01-15
Highest AACS version: 81
Drive platform: RS8600
Firmware version: E102/ID76
Seeking the ability to read UHD disks. Thank you.
PM sent.
Can I go back? I get the following errors (lots and lots of copies) when trying to read regular blu-ray devices.
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..0C5AB7BD762D5C4B01EA83F68D6773729A2 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E102
PM sent.
Please remove all power from the drive. Power adapter AND USB!!! Try again. If it will not work then please post again. The flash can be reverted if needed.
I performed this and it resolved the issue. It is odd, because I had powered everything down just the day before, so maybe something is flaky. Thank you for the recommendation.
Maybe your power down was too short and the caps kept the voltage up for some time and therefore the reset was not performed.
I am looking to update / cross-flash my Pioneer drive to fully support BDXL media and expand my LibreDrive capabilities. Here are the drive details:
Model: PIONEER BD-RW BDR-209M
Firmware: 1.50 (Original / unpatched)
Platform: RS8601
As my account is newly registered, the forum system does not allow me to send PMs yet.
@Coopervid, could you please send me a message regarding the appropriate flashing tool for this specific drive? I would gladly appreciate your help and am happy to cover your service fee.
Norbyload wrote: Fri Aug 21, 2026 3:16 pm
Hi everyone,
Platform: RS8601
Best regards!
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Hi everyone,
Platform: RS8601
mb2776 wrote: Sat Aug 22, 2026 9:09 pm
Hi guys, i m new here, i have an asus / pioneer drive, i just want to patch it. Why we cannot patch these drive alone like lg drive ?
Sadly no the pioneer auto flasher is not public
See below for email
Send me your makemkv drive info section
For everyone else no need to post your drive info section here just reach out directly to avoid the long post approval process
Post your Makemkv info and you will receive a PM afterwards.
Hi Coopervid, thanks for your answer, my Makemkv info below :
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E104
Serial number: Q**********L
Firmware date: 2017-06-14
Highest AACS version: 82
Firmware version: E104/ID71
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E104
