error code
obirob
error code
Post by obirob »
help with error codes please
original drive info
manufacturer.....ASUS
product...BW-16D1X-U
revision...A105
firmware date...2120-12-02....11.14
bus encryption flags...1F
libredrive info
status...possible, not yet enabled
drive platform...MT1959
flashed using mkv WH16NS60 1.02
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number:
Firmware date: 2117-11-24 14:13
Bus encryption flags: 1F
Highest AACS version: 63
Firmware version: 3.02
uhd 4k disk star wars the last jedi
starts in mkv
until this
MakeMKV v1.18.4 win(x64-release) started
Using LibreDrive mode (v06.3 id=96929CF53B04)
Downloading latest HK to C:\Users\obiro/.MakeMKV ...
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE ASUS BW-16D1HT 3.02 KLMP99E0743' at offset '765198336'
then it has to be ejected
have I used the correct flash if not what is the flash to use
and what does latest HK refer to
many thanks for any help you can give
to a OLDER nubbie
OBIROB
Re: error code
You have at least 2 issues
First one you hk failing to download
You can manually fix that with keydb see here: viewtopic.php?t=38293
The time out could be from a dirty disc try cleaning it.
