Public KeyDB Disc Submissions
allenpeak
Post by allenpeak » Mon Aug 24, 2026 3:08 am
Disc type: UHD
Disc ID: 44F6D7CB148774EC65B9890E71E8F8CF0E18A50E
Disc dump filename: MKB20_v82_Avatar-_Fire_and_Ash_7728
Drive: BD-RE BP60NB10
Drive firmware: 1.02
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private browsing? Yes
MKB_RO.inf link: https://u.pcloud.link/publink/show?code ... Fvs5m6vypX
Disc dump link: https://u.pcloud.link/publink/show?code ... Fvs5m6vypX
keydb_helper
Post by keydb_helper » Mon Aug 24, 2026 4:35 am
allenpeak wrote: Mon Aug 24, 2026 3:08 am Disc type: UHD
Thanks for the submission allenpeak but your disc was added to the public keydb on May 19.
Your log indicates a transient failure occurred whilst MakeMKV was trying to activate LibreDrive. Power down your drive completely, reboot your PC, make sure the keydb is in the correct location and you should be good to go.
