I just installed the application, I have AnyDVD HD on my machine running with the latest version, the drive is listed in 'my computer' and imgburn is seeing the drive. I cannot find any settings in MakeMKV that would allow my drive to be seen. the Blu-ray drive I am using is HL-DT-ST BDDVDRW CH08LS10 1.00
I enabled debugging and I am getting the following information:
MakeMKV v1.4.9 beta win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Aaron/MakeMKV_log.txt
FAILURE: Code 3221225488 at QW,Bt.0%[OfJ[h:213130927
FAILURE: Code 3221225488 at /CW2w&;*mYHK*iE#:121263061
FAILURE: Code 0 at /CW2w&;*mYHK*iE#:121262762
FAILURE: Code 0 at ~2`#___>*HYme6[_^0D<8^F#ih:29393516
The program can't find any usable optical drives.
Anyone have any suggestions since the source list is blank, and I have a Blu-ray drive and DVD-RW drive in my machine both are sata drives. Thank you.
Blu-Ray drive is not being seen by MakeMKV
Re: Blu-Ray drive is not being seen by MakeMKV
I get exactly the same problem. Running windows 7 , anydvd hd, virtual clonedrive.
Doesnt' matter, just copy the disc to ISO, then load that. But, still a bug none-the-less.
- Contact:
Apparently known problem with SATA drive and AHCI controller.
