I understand that this forum does not feature an Atom feed. I don't know if it's possible to add one but it would definitely be a useful feature.
Feed format
The standard phpBB feed is ATOM format, NOT RSS, some feed readers may not be able to properly read the ATOM format. Although valid ATOM, it is quite unusual structured. There are no plans to add RSS format support with phpBB 3.x.
How to enable and where do I see it
To enable the feed in its basic form, go to: ACP>General>Feed settings
1)Set "Enable Feeds" to "Enabled".
2)Set "Enable board-wide feed" to "Enabled"
Leave all the rest default to start with and Submit the change.
If you return to the Board Index page, your browser should show a selectable feed icon near the address bar (examples of: Internet Explorer 8 and Firefox 3.6) which will open the feed page.
Source: https://www.phpbb.com/support/docs/en/3 ... tom-feeds/
Atom Feed for Forum
Re: Atom Feed for Forum
Not likely to happen. The forum owner visits every couple of months, and no one else can install software here. And, frankly, there is a LOT of stuff that flat-out doesn't work here.
residentorca
I didn't know that. Appreciate you weighing in.Woodstock wrote: Mon Aug 24, 2026 12:45 am Not likely to happen. The forum owner visits every couple of months, and no one else can install software here. And, frankly, there is a LOT of stuff that flat-out doesn't work here.
