Flow 4kUHD Unable to Rip
SlapNTickle
Post by SlapNTickle » Thu Aug 20, 2026 8:08 pm
Hello!
I'm having some real trouble ripping the 2024 4kUHD film Flow. After flowing some other threads: I have gotten the latest KeyDB file through KeyDB assistant, and my drive has LibreDrive enabled with Make MKV having the java jadk-26.0.1. I have previously been able to rip other 4kUHD movies successfully, but this one I'm having real trouble with. Any and all help will be appreciated.
I have attached the log to the end of the post and here is the drive and disc info from Make MKV:
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO7P4EB4651
Highest AACS version: 82
Firmware version: 1.03
Disc Information
Label: FLOW
Timestamp: 2025-05-08 14:59:57
Protection: AACS2.0/C v82
Data capacity: 57.16 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
https://drive.google.com/file/d/1B2sSmg ... drive_link
Re: Flow 4kUHD Unable to Rip
Post by MartyMcNuts » Fri Aug 21, 2026 12:45 am
SlapNTickle wrote: Thu Aug 20, 2026 8:08 pm Hello!
Revision: 1.03
Disc Information
Label: FLOW
Number of layers: 2
Copy and paste the log text.
SlapNTickle
Post by SlapNTickle » Sat Aug 22, 2026 11:02 am
I'm not able to for some reason. It's 62 million characters. But I have split it off onto it's own drive link here: https://drive.google.com/file/d/1Tuk-Ql ... sp=sharing
Post by dcoke22 » Sat Aug 22, 2026 3:52 pm
Copied from the top of SlapNTickle's Google Drive link.
Debug log started at Thu Aug 20 19:42:44 2026 , written by MakeMKV v1.18.4 win(x64-release)
001005:0000 MakeMKV v1.18.4 win(x64-release) started
DEBUG: Code 0 at I4d{fg3a(vudG:Rh?<"SK6:;:121261704
DEBUG: Code 3221225486 at I4d{fg3a(vudG:Rh?<"SK6:;:121261727
DEBUG: Code 3221225486 at i^4-&RW&P8%g=4sa\JBJ:213130582
DEBUG: Code 3 at @"msWTt'T11F$o0`O'm,^T]+:29395310
SDF  v0a6: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MO7P4EB4651
001011:0000 Using LibreDrive mode (v06.3 id=866A98CB9C4E)
DEBUG: Code 101067008 at VJs9j8g7;i#^WIj*:121271617
DEBUG: Code 101067008 at `j<8k^nOmd,[xh~$:213130559
DEBUG: Code 100795393 at VJs9j8g7;i#^WIj*:121271617
DEBUG: Code 100795393 at `j<8k^nOmd,[xh~$:213130559
DEBUG: Code 100795393 at Y=~:l,CzPj`G]VmKN5:121263429
DEBUG: Code 100795393 at Y=~:l,CzPj`G]VmKN5:121262302
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO7P4EB4651' at offset '61126475776'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO7P4EB4651' at offset '30814699520'
002003:0000 Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO7P4EB4651' at offset '30814701568'
DEBUG: Code 0 at xOxA5slwFaQF_Np:121262509
DEBUG: Code 0 at xOxA5slwFaQF_Np:213129846
DEBUG: Code 1 at xOxA5slwFaQF_Np:29395264
005084:0000 Failed to load content hash table, unable to verify integrity of M2TS files.
Not enough power maybe?
Post by MartyMcNuts » Sun Aug 23, 2026 12:38 am
dcoke22 wrote: Sat Aug 22, 2026 3:52 pm Copied from the top of SlapNTickle's Google Drive link.
Being on Linux, the most likely culprits are:
1. Insufficient power. Use USB-C or USB3+ ports direct from the motherboard, not case ports or use an AC powered USB hub of at least 24w.
2. Using BU40N 1.03-MK firmware. MakeMKV on Linux has an issue with this firmware version. Flash the drive down to BU40N 1.00.
