Verbatim 43888 with BU40N Hitachi-LG
Diplomator
Post by Diplomator »
i just bought the Verbatim 43888 with BU40N Hitachi-LG drive.
and tried to understand the Flash guide but i am stuck a bit.
the MakeMKV says
Driveinformation
OS-Gerätename: D:
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.05
Serienummer: MO7PBC91619
Firmware-Datum: 2124-04-23 13:47
Markierungen der Bus-Verschlüsselung: 17
is it possible to flash ? is the Revision OK ?
and how does i make the Command ?
.\makemkvcon64.exe f --all-yes -d F: rawflash enc -i "C:\temp\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Sayaka
Re: Verbatim 43888 with BU40N Hitachi-LG
Post by Sayaka »
Open your cmd or Powershell terminal inside the folder where makemkvcon64.exe happens to be. Also, make sure HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin is inside the C:\temp\ folder
Then :
.\makemkvcon64.exe f --all-yes -d D: rawflash enc -i "C:\temp\HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin"
After that, power off the drive (if it's a Verbatim 43888 it should be an external drive, so you can just unplug it), and wait 30 seconds. Put the power back on (plug it back in), and enjoy. :)
Diplomator
i have no C:\Temp folder
should i create it ?
and where do i get the Firmware from ?
Diplomator wrote: Sat Aug 22, 2026 1:59 pm i have no C:\Temp folder
Temp is just an example of where to put the fe
see guide below
