UHD FAQ
boguslecina
Re: UHD FAQ
#181 Post by boguslecina » Sat Aug 22, 2026 9:50 am
Fixed version:
https://fvonline-db.bplaced.net/findvuk ... K_2.04.zip
It now requires manually launching FindVUK to select a language (English by default) or manually editing the file: FindVUK\config\FindVUK.ini
Section: [BlurayMeta]
PreferredLanguages = eng
Re: UHD FAQ
#182 Post by SamuriHL » Sat Aug 22, 2026 2:36 pm
Nalor fixed the issue. I just did a synchronize in KeyDB Assistant and everything works now.
Vacantcousin
Re: UHD FAQ
#183 Post by Vacantcousin » Fri Sep 25, 2026 1:08 am
Ready Player one UHD submitted
First submission be gentle at least lube plz :lol: :D
Disc type: UHD
Disc ID: Ready Player One
Disc dump filename: MKB20_v61_Ready_Player_One_E1B7.tgz
Drive:BW-16D1HT
Drive firmware: ASUS-BW-16D1HT-3.10-WM01601-211901041014
LibreDrive status:LibreDrive Information
Firmware version: 3.10
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing?yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://storage.to/c/3nJ8ofxqP
Disc dump link:https://storage.to/c/3nJ8ofxqP
this is now working thank you to everyone who got this one working
Barley
Re: UHD FAQ
#184 Post by Barley » Tue Sep 29, 2026 5:43 pm
@SamuriHL,
Thank you for the KeyDB_Assistant tool. It has allowed me to add several entries to the keydb.cfg file for my and others' benefit.
I did find a bug that is either in KeyDB_Assistant or findvuk. When I performed a Disc Info function on the No Time To Die Bonus Disc Blu-ray, it found the keys correctly, but you will see that it failed to parse the title correctly (maybe because it has a colon (:) in the title?). As a result, when it attempted validation and update of the keydb.cfg file, it errored out and corrupted the keydb.cfg file, to the point that I spent a half day trying to figure out why this disc was now making KeyDB_Assistant hang.
Thank you for checking this out.
  DISC INFORMATION
Validation Data     :
Media Key           :
VUK                 :
Unit Key 1          :
--- Disc Information ---
Disc ID      :
Volume       : NO_TIME_TO_DIE_BONUS_DISC
Title        : No Time to Die:
Bonus Disc
Date         : 2021-10-08
KeyDB Status:
Status       : not found
KeyDB entry mismatch detected
KeyDB entry updated
KeyDB Status        : not found for ---
KeyDB entry updated
2026-09-29 11:29:04 # 4814 # [E] bluray_keydb(493) / _Parse_Title / ERROR! Line is not a correct line with useable data! >Bonus Disc] | D | 2021-10-08
2026-09-29 11:29:04 # 4814 # [E] bluray_keydb(856) / _OpenFile_CFG / ERROR! Couldn't parse line as title! >Bonus Disc] | D | 2021-10-08
2026-09-29 11:29:04 # 4815 # [E] FindVUK_Main(3547) /  / ERROR! Couldn't open main keydb file! >#BRKDB_ERR_PARSE<
Re: UHD FAQ
#185 Post by SamuriHL » Tue Sep 29, 2026 9:33 pm
I have too many projects going on right now so it's not going to be looked at soon. When I get back into that code I'll take a look.
Barley
Re: UHD FAQ
#186 Post by Barley » Tue Sep 29, 2026 10:32 pm
That's fine! There is no rush. I was able to correct the entry manually. It just took me a while to figure out what was going on.
Re: UHD FAQ
#187 Post by SamuriHL » Wed Sep 30, 2026 3:14 am
Should be a very quick fix when I get a minute. My other projects are consuming my free time.
tommik128
Re: UHD FAQ
#188 Post by tommik128 » Sat Oct 17, 2026 10:19 am
I would like to report an error when clicking Disc Info on Harry Potter and the Order of the Phoenix standard blu-ray:
KeyDB Assistant 1.1.0.1
Unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Index was out of range. Must be non-negative and less than the size of the collection. (Parameter 'index').
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection. (Parameter 'index')
   at System.Collections.Generic.List`1.get_Item(Int32 index)
   at KeyDBAssistant.DiscUtils.getDiscInfo(String disc, String aacsDir)
   at KeyDBAssistant.KeyDBAssistant.btnDiscInfo_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(HWND hWnd, MessageId msg, WPARAM wparam, LPARAM lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
    Assembly Version: 8.0.0.0
KeyDB_Assistant
    Assembly Version: 1.1.0.1
System.Runtime
System.Drawing.Primitives
System.Threading
System.Collections
System.Drawing.Common
System.Diagnostics.Process
Microsoft.Win32.Primitives
System.Threading.Thread
Accessibility
    Assembly Version: 4.0.0.0
System.Memory
System.Diagnostics.FileVersionInfo
System.Numerics.Vectors
System.Resources.Extensions
System.Drawing
System.Collections.Concurrent
System.ObjectModel
System.ComponentModel
Microsoft.Win32.SystemEvents
System.Linq
System.Collections.NonGeneric
Microsoft.Win32.Registry
System.Text.Encoding.CodePages
System.Private.Uri
System.Net.Http
Serilog
    Assembly Version: 4.3.0.0
Serilog.Sinks.File
    Assembly Version: 7.0.0.0
System.Diagnostics.DiagnosticSource
System.Diagnostics.Tracing
System.Net.WebClient
System.Console
System.Threading.ThreadPool
System.Management
    Assembly Version: 10.0.0.1
System.Text.Json
System.Xml.ReaderWriter
System.Private.Xml
System.IO.FileSystem.DriveInfo
System.Security.Cryptography
System.Runtime.Loader
System.Diagnostics.StackTrace
System.Reflection.Metadata
System.Collections.Immutable
************** JIT Debugging **************
When I click Continue the application just stays frozen.
