Hey all, I'm a noob to ripping UHD and I'm having some issues flashing this drive. I'm using SDFtool Flasher as administrator. Tried a few different cables now as well. I have the Benfei and recommended Slim adapter. It is connected via USB to my laptop, the drive recognizes though it wont actually play a UHD disk through VLC. I am trying to flash to DE_LG_BU40N.
Product: BD-RE BU50N
Revision: CC02
Serial number: 911HS000697
Firmware date: 2119-05-10 11:30
Bus encryption flags: 1F
Highest AACS version: 65
Kinda at a loss at this point, any help would be severely apricated. SDFtool reports it has successfully flashed but I have experienced no change to the info in MakeMKV.
Thanks in advance!
BU50N Troubles
Sayaka
Re: BU50N Troubles
Have you tried the following :
Flash either BU40N 1.03-MK or BU40N 1.00-DE with a regular WRITE, no encryption, no bootloader flash, no RECOVER.
(And if that fails, try flashing BU40N 1.03-MK with encryption I guess, but I seriously doubt that would be necessary).
EEK009
Re: BU50N Troubles
I have no idea why I was checking encrypted Firmware but you are correct I did not need it on and it worked first try....
I am happy it worked but upset it was that easy
Thanks for your help Sayaka!!
