UHD FAQ
boguslecina
Re: UHD FAQ
Post by boguslecina »
New version of FindVUK
http://fvonline-db.bplaced.net/findvuk/FindVUK_2.05.zip
KeyDB Assistant can't update to FindVUK 2.05 from 2.04, I have newest KeyDB Assistant 1.1.0.1
Re: UHD FAQ
Post by SamuriHL »
No one can. It's broken. Nalor will have to fix FindVUK. Has nothing to do with KeyDB Assistant at all.
boguslecina
Re: UHD FAQ
Fixed version:
https://fvonline-db.bplaced.net/findvuk ... K_2.04.zip
It now requires manually launching FindVUK to select a language (English by default) or manually editing the file: FindVUK\config\FindVUK.ini
Section: [BlurayMeta]
PreferredLanguages = eng
Re: UHD FAQ
Post by SamuriHL »
Nalor fixed the issue. I just did a synchronize in KeyDB Assistant and everything works now.
