Hey everyone,
I have a Zombieland UHD that I'd like to back up.
I don't know why, but the *.tgz file is about 35MB and it's not getting any smaller, even after several attempts.
How would you recommend sending this file? I tried sending it via Google Drive, but I don't think anyone will open the link.
Any suggestions?
Zombieland UHD
Re: Zombieland UHD
If it is AACS 2.1 and the dump ends in CC8A or 1C8C it can't be backed up.Photozone wrote: Wed Feb 18, 2026 8:45 am Hey everyone,
Any suggestions?
viewtopic.php?f=12&t=20549
There's other threads too.
Re: Zombieland UHD
Thanks for the reply.
The file name is MKB21_v70_Zombieland_0C05.tgz but with 35.653kb in size.
So it should be possible, I think?
Re: Zombieland UHD
In that linked thread, someone emailed the tgz dump back in 2022, so if the key is still unknown 4 years later, then I'd say the 0C05 variant is another one that can't be backed up.Photozone wrote: Wed Feb 18, 2026 9:33 am Hi,
Re: Zombieland UHD
It seems i have the same 4k Version of Zombieland 0C05 i was hoping to be able to rip it someday but maybe im out of luck. Have be satisfied with the 1080p version for now.
Re: Zombieland UHD
So i got the 2-Movie Collection and Zombieland Double Tap was no problem but sadly i too have the 0C05 version of Zombieland.
Before i buy another Version of the Movie, has anyone found a version that worked? Preferably on the european market and ideally german market?
Re: Zombieland UHD
I had to buy a secondhand copy from Half Priced Books that thankfully had the old key. Unfortunately there’s no way of knowing which key your disc has until you try to rip it or possibly inspect the ring code. (No I don’t know if there’s a difference in the ring codes but I would suspect there is).
