Hi there,
on my Mac I have in my profile the version below. And some BRs like Der letzte Kaiser german version does not work. May be I need to update my AACS version. But I do not know where I to download and how to install.
Aktuelles Profil: BD-ROM
Produzent: TSSTcorp
Produkt: BDDVDW SE-506AB
Revision: TS00
Serienummer: R8LC6GWBA12407
Markierungen der Bus-Verschlüsselung: 1F
Highest AACS version: 68
BR Problem on my Mac
Re: BR Problem on my Mac
The 'Highest AACS version' number that MakeMKV displays is just a listing of the highest AACS version that optical drive has seen. There's nothing for you to install to change it.
Does MakeMKV show some error messages when you try to rip Der letzte Kaiser?
klaus_moers
yes, but unfortunately only in German language. Telling me I need a higher version.
Diese Disk verwendet eine neuere Version des AACS-Schutzes. Bitte informieren Sie uns darüber auf http://www.makemkv.com/a/?HbDXsrH7ptxIpk...
AACS Ausgabedatei als /Users/local/Library/MakeMKV/MKB_v15_Der_letzte_Kaiser_E726.tgz gesichert
Der Volumenschlüssel für die DVD/Blu-ray ist unbekannt - das Video kann nicht entschlüsselt werden
Das Öffnen der Disk schlug fehl
Direkter Zugriffsmodus wird verwendet
Inhalte-Hashtabelle geladen, überprüfe Integrität der M2TS-Dateien.
Usually the version of AACS on the disc is embedded in the name of the .tgz dump file. That would suggest the disc uses AACS 15.Translated wrote:This disk uses a newer version of AACS protection. Please inform us at http://www.makemkv.com/a/? HbDXsrH7ptxIpk...
AACS output file as /Users/local/Library/MakeMKV/MKB_v15_Der_letzte_Kaiser_E726.tgz
The volume key for the DVD/Blu-ray is unknown - the video cannot be decrypted
Opening the disk failed
Direct access mode is used
Content hash table loaded, check the integrity of the M2TS files.
According to blu-ray.com the oldest release of the German version of The Last Emperor (1987) is in 2011. I don't know which version you have, but it is plausible that a disc from 2011 might be AACS 15.
I would expect MakeMKV to handle old versions of AACS like that easily. Perhaps there is something else wrong.
klaus_moers
it is just what the app is telling me. Then I follow this instructions.
Sayaka
Try downloading this : http://fvonline-db.bplaced.net/fv_download.php?lang=eng
Extract it. Rename keydb.cfg to KEYDB.cfg and place it inside ~/Library/MakeMKV/
Then restart MakeMKV, try opening the disc with MakeMKV again and let me know how it goes. I believe it should fix your issue.
And that's a version that is in KEYDB.cfg and it indeed uses AACS 15, which is why I believe the above should solve klaus_moers' problem.
2009, actually : https://www.blu-ray.com/movies/The-Last ... -ray/6352/According to blu-ray.com the oldest release of the German version of The Last Emperor (1987) is in 2011.
klaus_moers
I also get more problems with other discs.
I think there should be a patch version somewhere for me.
Diese Disk verwendet eine neuere Version des AACS-Schutzes. Bitte informieren Sie uns darüber auf http://www.makemkv.com/a/?+WtymNyDKIwjx3...
AACS Ausgabedatei als /Users/local/Library/MakeMKV/MKB_v63_Die_Erfindung_der_Wahrheit_1458.tgz gesichert
I wonder if you're missing the sdf.bin file? Or some other important file?
The first post mentions you're on a Mac. If you look in Macintosh HD/Users/<your username>/Library/MakeMKV what's in there?
