Build fails with FFmpeg 9.0
Toad King
Post by Toad King »
New version of FFmpeg removed some APIs MakeMKV was using.
libffabi/src/ffabi.c: In function ‘set_codec_info_extended’:
libffabi/src/ffabi.c:542:22: error: ‘AVCodec’ has no member named ‘ch_layouts’
  542 |     if (NULL != codec->ch_layouts) {
libffabi/src/ffabi.c:543:26: error: ‘AVCodec’ has no member named ‘ch_layouts’
  543 |         while (0 != codec->ch_layouts[count_ch_layouts_in].nb_channels)
libffabi/src/ffabi.c:561:45: error: ‘AVCodec’ has no member named ‘ch_layouts’
  561 |         if (AV_CHANNEL_ORDER_NATIVE != codec->ch_layouts[i].order) continue;
libffabi/src/ffabi.c:562:56: error: ‘AVCodec’ has no member named ‘ch_layouts’
  562 |         channel_layouts[count_ch_layouts_out++] = codec->ch_layouts[i].u.mask;
libffabi/src/ffabi.c: In function ‘ffm_audio_get_codec_information’:
libffabi/src/ffabi.c:589:31: error: ‘AVCodec’ has no member named ‘supported_samplerates’
  589 |     info->sample_rates = codec->supported_samplerates;
libffabi/src/ffabi.c:593:22: error: ‘AVCodec’ has no member named ‘ch_layouts’
  593 |     if (NULL == codec->ch_layouts) {
libffabi/src/ffabi.c:612:14: error: ‘AVCodec’ has no member named ‘sample_fmts’
  612 |     if (codec->sample_fmts) {
libffabi/src/ffabi.c:614:22: error: ‘AVCodec’ has no member named ‘sample_fmts’
  614 |             if (codec->sample_fmts[i]==AV_SAMPLE_FMT_NONE)
libffabi/src/ffabi.c:616:77: error: ‘AVCodec’ has no member named ‘sample_fmts’
  616 |             info->sample_formats[i]=(uint8_t)back_translate_sample_fmt(codec->sample_fmts[i]);
echo_x
Re: Build fails with FFmpeg 9.0
Post by echo_x »
I ran into the same issue.
I downloaded both tarballs and extracted them to their own folders.
While running make:
I received this error message:
objcopy --strip-all --strip-debug --strip-unneeded --discard-all out/libdriveio.so.0.full out/libdriveio.so.0
mkdir -p tmp/libffabi/src/
gcc -c -g -O2 -D_linux_ -Wno-deprecated-declarations  -D_GNU_SOURCE -D_REENTRANT -otmp/libffabi/src/ffabi.c.o -I./libabi/inc -I.
/libffabi/inc \
-DHAVE_BUILDINFO_H -Itmp  -fPIC libffabi/src/ffabi.c
 542 |     if (NULL != codec**->ch_layouts) {
 616 |             info->sample_formats[i]=(uint8_t)back_translate_sample_fmt(codec->**sample_fmts[i]);
make: *** [Makefile:84: tmp/libffabi/src/ffabi.c.o] Error 1
I used Python to modify libffabi/src/ffabi.c to change the API calls
python - <<'PY'
from pathlib import Path
p = Path("libffabi/src/ffabi.c")
s = p.read_text()
start = s.index("#ifndef FFABI_HAVE_OLD_CHANNEL_LAYOUT\nstatic int set_codec_info_extended")
end = s.index("\nFFM_AudioConvert* __cdecl ffm_audio_convert_alloc", start)
replacement = r'''#ifndef FFABI_HAVE_OLD_CHANNEL_LAYOUT
static int set_codec_info_extended(FFM_CodecInfo* info, const AVCodec* codec)
    char* exinfo;
    size_t len;
    int count_ch_layouts_in = 0;
    unsigned int count_ch_layouts_out = 0;
    uint64_t* channel_layouts;
    const AVChannelLayout* ch_layouts = NULL;
    unsigned int i;
    int ret;
    len = strlen(codec->name);
    if (len >= FFM_CODEC_INFO_NAME_MAX_LENGTH) return -1;
    ret = avcodec_get_supported_config(
        NULL, codec, AV_CODEC_CONFIG_CHANNEL_LAYOUT, 0,
        (const void**)&ch_layouts, &count_ch_layouts_in
    if (ret < 0) return -1;
    exinfo = (char*)ffabi_memalign(
        sizeof(uint64_t),
        FFM_CODEC_INFO_NAME_MAX_LENGTH +
        FFM_CODEC_INFO_EXMARK_LENGTH +
        ((count_ch_layouts_in + 1) * sizeof(uint64_t))
    if (NULL == exinfo) return -1;
    memcpy(exinfo, codec->name, len + 1);
    memcpy(exinfo + FFM_CODEC_INFO_NAME_MAX_LENGTH,
           FFM_CODEC_INFO_EXMARK_MAGIC,
           FFM_CODEC_INFO_EXMARK_LENGTH);
    channel_layouts = (uint64_t*)(
        exinfo +
    info->name = exinfo;
    info->channel_layouts = channel_layouts;
    for (i = 0; i < (unsigned int)count_ch_layouts_in; i++) {
        if (AV_CHANNEL_ORDER_NATIVE != ch_layouts[i].order)
            continue;
    channel_layouts[count_ch_layouts_out] = 0;
    return 0;
#endif
int __cdecl ffm_audio_get_codec_information(
    const char* name,
    int encode)
    AVCodec* codec;
    const int* sample_rates = NULL;
    const enum AVSampleFormat* sample_fmts = NULL;
#endif
    int num_sample_rates = 0;
    int num_sample_fmts = 0;
    int num_ch_layouts = 0;
#endif
    int ret;
    int i;
    memset(info, 0, sizeof(*info));
    if (encode) {
        codec = (AVCodec*)avcodec_find_encoder_by_name(name);
    } else {
        codec = (AVCodec*)avcodec_find_decoder_by_name(name);
    if (!codec)
        return ffmerr(1, encode);
    info->name = codec->name;
    info->long_name = codec->long_name;
        NULL, codec, AV_CODEC_CONFIG_SAMPLE_RATE, 0,
        (const void**)&sample_rates, &num_sample_rates
    if (ret < 0)
        return ffmerr(2, 0);
    info->sample_rates = sample_rates;
#ifdef FFABI_HAVE_OLD_CHANNEL_LAYOUT
    info->channel_layouts = codec->channel_layouts;
#else
        (const void**)&ch_layouts, &num_ch_layouts
    if (ret < 0)
    if (NULL == ch_layouts) {
        info->channel_layouts = NULL;
    } else {
        if (set_codec_info_extended(info, codec))
#endif
    info->id = codec->id;
    info->capabilities = codec->capabilities;
    if (codec->profiles) {
        for (i = 0; i < 32; i++) {
            if (codec->profiles[i].profile == AV_PROFILE_UNKNOWN)
                break;
            info->profiles_names[i] = codec->profiles[i].name;
            info->profiles_values[i] = codec->profiles[i].profile;
            info->profiles_count = i + 1;
        NULL, codec, AV_CODEC_CONFIG_SAMPLE_FORMAT, 0,
        (const void**)&sample_fmts, &num_sample_fmts
    if (ret < 0)
    if (sample_fmts) {
        for (i = 0; i < num_sample_fmts && i < 16; i++) {
            info->sample_formats[i] =
                (uint8_t)back_translate_sample_fmt(sample_fmts[i]);
            info->sample_formats_count = i + 1;
    return 0;
p.write_text(s[:start] + replacement + s[end:])
print("Patched:", p)
PY
I then used make clean and continued through the install.
Afterwards, I was able to open the software
Sayaka
Post by Sayaka »
I have not yet attempted to rip a disc from my Arch distrobox after patching, but I have to thank you for this. After updating to ffmpeg 9 and using your patch, I was able to launch MakeMKV with no issues.
For anyone who's wondering, this is what I did on my Arch distrobox on my Ubuntu LTS-based system :
1) Used "sudo pacman -Rcn makemkv" to remove the AUR package
2) Used the makemkv-oss-1.18.4 and and makemkv-bin-1.18.4 that I had previously downloaded from the main website, rather than the AUR package
3) Created an empty file named "ffmpegpatch.py" inside the makemkv-oss-1.18.4 folder
4) Pasted the following code into the file then saved the file :
s = p.read_text()
    char* exinfo;
    size_t len;
    unsigned int i;
    int ret;
        sizeof(uint64_t),
        exinfo +
            continue;
    return 0;
#endif
    const char* name,
    int encode)
    AVCodec* codec;
#endif
#endif
    int ret;
    int i;
    if (encode) {
    } else {
    if (!codec)
    if (ret < 0)
#else
    if (ret < 0)
    } else {
#endif
                break;
    if (ret < 0)
    if (sample_fmts) {
    return 0;
(I had to delete the first and last lines as they caused the python script to not work properly on my system)
5) Inside the distrobox, confirmed that the problem was happening by running "./configure" and "make" inside the makemkv-oss-1.18.4 folder
6) Ran "make clean"
7) Used the command "python ffmpegpatch.py" inside that same folder
8 ) Ran "./configure" and "make" again
9) Ran "sudo make install"
10) Inside the makemkv-bin-1.18.4 folder, ran "make", accepted the license, then ran "sudo make install"
11) Launched MakeMKV with no issues.
(Now I probably just need to do the whole symlink thingy again if I want to be 100% sure I can have direct UHD disc playback once again when using Kodi.)
TheCrazyCanuck
Post by TheCrazyCanuck »
If you build MakeMKV from sources like me, this is how I fixed the issue on CachyOS (copy and paste from my notes):
1) Remove ffmpeg from pacman so it won't be updated automatically which caused the issue in the first place (FFMpeg 9):
a) Open /etc/pacman.conf
b) Find line with "IgnorePkg"
c) Edit the line from step 1b to IgnorePkg = ffmpeg
2) Download FFMpeg 8 from their website or git
3) Navigate to the extracted FFMpeg sources and configure it to be linkable externally
a) ./configure --enable-shared
4) Make and install FFMpeg 8:
a) make
b) sudo make install
5) Rebuild MakeMKV OSS so that it uses FFMpeg 8 moving forward.
If you want to build MakeMKV from sources there are some other packages like build-essentials which contains the compilers that need to be installed first. This is how I build the Bin and OSS:
MakeMKV OSS:
1) Unpack the source tarball: tar -xvf makemkv-oss-x.y.z.tar.gz
2) Enter the directory: cd makemkv-oss-x.y.z
3) Configure the build: ./configure
4) Compile the files: make
5) Install the binary: sudo make install
MakeKMV Bin:
1) Unpack the binary tarball: tar -xvf makemkv-bin-x.y.z.tar.gz
2) Enter the directory: cd makemkv-bin-x.y.z
lmm5247
Post by lmm5247 »
There is now a patch for the AUR package on Arch
https://aur.archlinux.org/packages/makemkv
Sayaka
Post by Sayaka »
Thank you. I also found this :
https://aur.archlinux.org/packages/makemkv-working
Which "freezes" MakeMKV to version 1.17.7, for those who want it.
Mr. ---
Post by Mr. --- »
Here's how I solved it
1.18.4-1 ----> 1.18.4-2
CachyOS
paru -S makemkv
After confirmation, it displays the PKGBUILD in the console.
Don't do anything yet.
## Place the two packages in the following folder
/home/***/.cache/paru/clone/makemkv/
makemkv-bin-1.18.4.tar.gz
makemkv-oss-1.18.4.tar.gz
## Open the PKGBUILD file with an editor (kate)
source=(makemkv-bin-${pkgver}.tar.gz
makemkv-oss-${pkgver}.tar.gz
## Now you can press “q” to make the PKGBUILD disappear from the console.
Then the installation should run through.
