Does BDR-S12JX with 1.05 firmware support UHD ripping
liups233
Post by liups233 »
Years ago I bought a Vinpower BDR-212DBK, and asked the reseller to flash it to BDR-S12JX. However, he flashed it to the latest firmware 1.05, which did not supported by LibreDrive at that time.
Fortunately this version is supported now. DVD and 1080P Blu-ray ripping works perfect. But I'm unsure whether this drive/firmware combination can successfully rip UHD discs.
If someone could confirm whether this drive supports UHD ripping, I'd be able to pick up some cheap second-hand UHD discs for testing. Any guidance would be greatly appreciated. Thanks!
Here is the drive info:
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S12JX
Revision: 1.05
Serial number: DADL######WL (redacted)
Firmware date: 2023-08-01
Highest AACS version: 32
Drive platform: RS8F01
Firmware version: 1.05/ID72
Re: Does BDR-S12JX with 1.05 firmware support UHD ripping
Yes should do UHD as of last November
liups233
Post by liups233 »
Billycar11 wrote: Fri Aug 21, 2026 12:35 pm Yes should do UHD as of last November
Glad to hear, thanks!
