Site down, can't buy a license or activate the trial
All topics related to functioning of this forum or MakeMKV website
Re: Site down, can't buy a license or activate the trial
charly700 wrote: Wed Aug 19, 2026 7:05 pm Thanks. Changing the date didn't help. The small dialog box still pops up.
Message: Application failed to initialize
NO_ANSWER_FROM_MAKEMKVCON
Then click OK, and the dialog box disappears.
I use Manjaro XFCE and MakeMKV 1.18.4-1
Edit: Okay. It seems to have something to do with ffmpeg 2:9.0-5. What can I do about it?
Ffmpeg issue
https://www.reddit.com/r/makemkv/s/2GtTeQsUiA
guanciale!
Post by guanciale! »
They bumped pkgrel=2 on AUR already, because they added a patch! :wink:
paru (or yay) will upgrade to 1.18.4-2 without issues.
:twisted: cook until you are hungry :twisted:
charly700
Post by charly700 »
Thanks to everyone.
The last tip helped. Before that, I'd also tried the tip from Reddit, and that worked, too. But the last tip also fixed the problem where an update kept popping up.
CaelThunderwing
Post by CaelThunderwing »
was about to use it to backup my copy of an dvd set to perserve the orginals, and yea.. its the end of august. and thinsg are still down, has no one heard from the owner still?
snl20
Post by snl20 »
seems the site is back up :D
Daisame
Post by Daisame »
Still can't buy a license though. Seems the payment processing may be an issue. Hope to see a solution. I have money I would like to give. :wink:
killertofu88
Post by killertofu88 »
I'm stuck... Updated to version 2.0 and it says it expires in Jan 2027, but when I try to get into ripping a disk it tells me the evaluation period is expired. When I try to enter the latest beta key (which I know expires tomorrow) it tells me the software is too old. I'd love to just purchase this, but I keep seeing posts that it's not possible...
killertofu88 wrote: Wed Sep 30, 2026 5:16 pm I'm stuck... Updated to version 2.0 and it says it expires in Jan 2027, but when I try to get into ripping a disk it tells me the evaluation period is expired. When I try to enter the latest beta key (which I know expires tomorrow) it tells me the software is too old. I'd love to just purchase this, but I keep seeing posts that it's not possible...
Do not use v2.0.0. It has lots of problems. Go back to v1.18.4.
Post by d00zah »
MartyMcNuts wrote: Thu Oct 01, 2026 1:35 am
But at least one user reports Help > Purchase link now works in v2.0.0? Try to buy a key before downgrading?
viewtopic.php?p=206076#p206076
Henkjan
Post by Henkjan »
d00zah wrote: Thu Oct 01, 2026 11:27 am
yes, from v2.0.0, help menu, purchase one ends up on the page with the beta key. should function until the end of this month. (making a backup of a blu-ray disc as I type this, seems to be going just fine; 45minutes remaining)
