Is there another graphical user interface for MakeMKV?
Is it generally permitted to create a new graphical user interface for MakeMKV yourself?
If yes, is it allowed to publish it?
Free of charge
Other Graphical User Interface for MakeMKV ?
Re: Other Graphical User Interface for MakeMKV ?
But who can it now ?
Maybe with an AI?
For Windows, Linux or macOS?
What is your idea for a look?
I use currently Kubuntu
Best regards
Viele Grüße
R22D22
Viele Grüße
R22D22
I have a new GUI.
It runs under Windows.
Here is a screenshot
https://www.dropbox.com/scl/fi/oinm8s5i ... 8iv96&dl=0
In the moment only in german
IS IT ALLOWED to create a new one ?
Is it allowed to bring them ONLINE for free download for other ?
- Automaticly read disc after close
- Automaticly analyse Quickinformation
- Automaticly check you destination HDD for Free Space, Sytem (NTFS, exFAT and so on)
- Automaticly Telegram infos about start, end, error, after 10 or 20 or 66%
- Automaticly, open tray, open folder
- Automaticly create LOGS and copy them to a special folder
- Automaticly create Foldersnames after MEDIA SCAN for Example:
THE EXPENDABLES [UHD] [DOLBY ATMOS 7.1 GER ENG] [EXTENDED DIRECTORS CUT] - Automaticly check new Version and Beta Key is available
Is it possible that there is also a Linux variant?
Which programming language and libraries were used?
I thought you were looking for a GUI, but I guess you built a new one
Could this be built with PySide6? Because you could get it running on Windows, Linux and possibly macOS, if it would be possible...
## Deutsch ##
Ist es möglich, dass auch eine Linux-Variante gibt?
Welche Programmiersprache und Bibliotheken wurden verwendet?
Ich dachte, dass du nach einer GUI suchst, aber du hast wohl eine neue gebaut
Ob dies wohl auch mit PySide6 gebaut werden könnte? Denn man könnte es sowohl auf Windows, Linux und ggf. macOS zum laufen bringen, sofern es möglich wäre…
## Deutsch ##
Best regards
Viele Grüße
R22D22
Viele Grüße
R22D22
MorkFromOrk
Wow, that looks fantastic!Bandito wrote: Fri Aug 14, 2026 2:25 pm I have a new GUI.
ThanksMorkFromOrk wrote: Wed Aug 19, 2026 8:32 pmWow, that looks fantastic!Bandito wrote: Fri Aug 14, 2026 2:25 pm I have a new GUI.
here 2 other new Screenshots
https://www.dropbox.com/scl/fi/l518qhjf ... ml4kr&dl=0
https://www.dropbox.com/scl/fi/fifhdz0y ... q0vwd&dl=0
Embedded Picture will not work here ?
This Picture show the automaticly TAG System.
After full backup they analyyse the Movie in up to 5-7 seconds and bring you this colored Automaticly tags.
You can choose audio or video are first or the year...
For the year you must go to TMDB and choose one of the 10 proposed movies.
And then they make, if you want a NEW Foldername looks like the end.
Next version i will changed from [ ] to ( ) or you can choose it in the Settings.
