PM sent.AxemRanger wrote: Sat Aug 08, 2026 6:30 am Feel I might have originally posted in a wrong thread. Whoops. Looking for a firmware to cross flash an XD05
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Firmware date: 2014-12-26
Highest AACS version: 82
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
LibreDrive for Pioneer drives
AxemRanger
Much appreciated. When doing the crossflash, does that retain the burning capabilities (up to BDXL 100gb discs) or does it becoming a read only drive? Thanks again!Coopervid wrote: Sat Aug 08, 2026 9:45 amPM sent.AxemRanger wrote: Sat Aug 08, 2026 6:30 am Feel I might have originally posted in a wrong thread. Whoops. Looking for a firmware to cross flash an XD05
Revision: 3.01
Yes. No disadvantages.AxemRanger wrote: Sat Aug 08, 2026 12:58 pmMuch appreciated. When doing the crossflash, does that retain the burning capabilities (up to BDXL 100gb discs) or does it becoming a read only drive? Thanks again!Coopervid wrote: Sat Aug 08, 2026 9:45 amPM sent.AxemRanger wrote: Sat Aug 08, 2026 6:30 am Feel I might have originally posted in a wrong thread. Whoops. Looking for a firmware to cross flash an XD05
Revision: 3.01
Product: BD-RW BDR-212BK
Revision: 1.04
Firmware date: 2022-12-20
Firmware version: ID81
Revision: 1.04
PM sent.Hucz89 wrote: Mon Aug 10, 2026 3:49 am Drive Information
Revision: 1.04
Revision: 1.04
see email belowCoopervid wrote: Mon Aug 10, 2026 8:08 pmOnly Billy can help you as this firmware is too new for the flasher.Hucz89 wrote: Mon Aug 10, 2026 3:43 am
Revision: 1.04
Serial number: <redacted>
Hello everyone,
First of all, thank you for all your hard work—it is greatly appreciated.
I own this drive, and since it is an older-generation model, I was not expecting it to support LibreDrive. However, I noticed that some users have successfully enabled LibreDrive on similar models, so I would like to share my drive information below and ask whether LibreDrive support is possible for this device.
OS device name: H:
Product: BD-RW BDR-S09
Revision: 1.10
Serial number: MLDL002732WL
Firmware date: 2013-10-15
Drive platform: RS8600
Firmware version: 1.10/ID43
OS device name: H:
Revision: 1.10
sure email me that info and all others email me no need to post your info here just reach out to me directlyDaxxar wrote: Tue Aug 11, 2026 2:13 pm Hello everyone,
OS device name: H:
Revision: 1.10
see below for email
please add PIONEER BD-RW BDR-TD04. Also under win 11 pro device mgr i'm getting: STATUS_DEVICE_POWER_FAILURE This device cannot start (Code 10).
That is not a makemkv issue you have other issues maybe low power USB port or bad case hopefully not bad drivewmr07 wrote: Tue Aug 18, 2026 8:17 pm please add PIONEER BD-RW BDR-TD04. Also under win 11 pro device mgr i'm getting: STATUS_DEVICE_POWER_FAILURE This device cannot start (Code 10).
Thanks a lot, Billy. It flashed successfully.Billycar11 wrote: Tue Aug 11, 2026 9:20 pmsure email me that info and all others email me no need to post your info here just reach out to me directlyDaxxar wrote: Tue Aug 11, 2026 2:13 pm Hello everyone,
OS device name: H:
Revision: 1.10
see below for email
Hello, could you please help me?
I have a Pioneer optical drive – specifically, the optical drive used in the Sharp Blu-ray recorder – which was custom-made by Sharp for Pioneer.
Operating System Device Name: K:
Product: BD-RW BDR-L13SH
Revised Version: 1.18
Firmware date: 2021-01-22
Status: Feasible, but not yet enabled
Drive Platform: Pioneer RS8C00
Firmware Version: ID92
Not inserted
When playing discs with high bitrates, the playback speed is limited to approximately 2X.
The two attachments to this email include "private_data.tar" is used to manually download an SDF.bin file.Run Makemkv after Bin is launched; it will create its own executable file.The power-off and reboot operations have all been performed. Request assistance to enable LibreDrive status.
thanks very much!
Not inserted
thanks very much!
