Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Post by Billycar11 » Wed Aug 19, 2026 9:45 am
burgermeister wrote: Tue Aug 18, 2026 1:30 am Hi,
I've been using this drive for some time now with Blu-Rays and have started on the 4K UHD ones. If this drive is capable of reading them, could you please send me the firmware?
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.03
Serial number: RGDL5-------
Firmware date: 2015-05-14
Highest AACS version: 65
Drive platform: RS8510
Firmware version: 1.03/ID19
Thank you!
sure email me that info and
all others email me no need to post your info here publicly just reach out to me directly
see below for email
flasher sent
Rare329
Post by Rare329 » Thu Aug 20, 2026 1:17 am
Coopervid wrote: Wed Apr 02, 2025 12:12 pm
zittrig wrote: Wed Apr 02, 2025 7:35 am Generally asked:
Are there any differences between
- BDR-UD03
- BDR-UD03B
- BDR-UD03TBD
Are the B and TBD flashable to BDR-UD04 like the BDR-UD03 when the firmware is older then 12/2022?
MakeMKV information not available, but perhaps there are any empirical values?
I could get one of them for a friend who has an empty enclosure since his BU40N is gone.
Not really. The only thing seems to be the firmware version should be 8510 or 8511. It looks like 8591 (see above) is not flashable. Maybe the author forgot to add this or nobody has it tried before so 8591 is excluded.
Can you help me flash my ud03tbd?
Product: BD-RW BDR-UD03D
Revision: 1.00
Serial number: OCDL048015WL
Firmware date: 2014-05-14
Highest AACS version: 76
Firmware version: 1.00/ID84
Post by Billycar11 » Thu Aug 20, 2026 1:43 am
Rare329 wrote: Thu Aug 20, 2026 1:17 am
Revision: 1.00
see below for email
Post by Coopervid » Thu Aug 20, 2026 9:19 am
- BDR-UD03
- BDR-UD03B
- BDR-UD03TBD
Revision: 1.00
PM sent.
Marksimus
Post by Marksimus » Thu Aug 20, 2026 2:15 pm
Hello Folks, I am in the same boat.
I can follow the flash directions just need some direction.
Very much appreciated for this forum and the folks that help out.
BD-RE PIONEER BD-RW BDR-UD03 1.14 DDDL527693WL
Revision: 1.14
Serial number: DDDL527693WL
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Cant recall if I did anything with this I have been recovering from a accident and just getting back into things
Thanks again :)
ahai88
Post by ahai88 » Thu Aug 20, 2026 3:34 pm
Hi Coopervid,
I have the same problem with the drive wthen name differs by one letter BDR-UD03D.
Can I also unlock UHD? Does the letter D change much :(
Device: \\.\E:
Drive Information:
Model Name : PIONEER BD-RW BDR-UD03D
Firmware Rev : 1.00
Extra Info : 14/05/14 PIONEER
Serial Number : OGDL091378WL
Buffer Size : 4000 kiB
Additional Drive Information:
Label Code : ----
Hardware Rev : SAT 8510
Kernel Type : ID84
Firmware Type : ID84
Kernel Version : 0000
Drive is in normal mode.
Firmware flashing support : NO
Firmware dumping support : NO
Drive Capabilities:
CD-ROM : R BD-ROM : R
CD-R : R/W BD-R : R/W
CD-RW : R/W BD-R XL : R/W
DVD-ROM : R BD-RE : R/W
DVD-R : R/W BD-RE XL : R/W
DVD-R DL : R/W HD DVD-ROM : -
DVD-RW : R/W HD DVD-R : -
DVD+R : R/W HD DVD-R DL : -
DVD+R DL : R/W HD DVD-RW : -
DVD+RW : R/W LabelFlash : NO
DVD-RAM : R/W LightScribe : NO
Drive Region Settings:
RPC Scheme : RPC-2
Current Region : 2
Changes Left : 4 (available to user)
Resets Left : 4 (available only to vendor)
Region State : Region is set
Thank you for your help ;)
Post by Coopervid » Thu Aug 20, 2026 3:51 pm
Marksimus wrote: Thu Aug 20, 2026 2:15 pm Hello Folks, I am in the same boat.
Revision: 1.14
Thanks again :)
PM sent.
Post by Coopervid » Thu Aug 20, 2026 3:53 pm
ahai88 wrote: Thu Aug 20, 2026 3:34 pm Hi Coopervid,
Device: \\.\E:
Drive Information:
Firmware Rev : 1.00
Label Code : ----
Kernel Type : ID84
Drive Capabilities:
RPC Scheme : RPC-2
Current Region : 2
PM sent.
ahai88
Post by ahai88 » Thu Aug 20, 2026 4:24 pm
The firmware which you sent me shows the firmware and the drive doesn't match.
USBSTOR\CdRomPIONEER_BD-RW__BDR-UD03D1.00
USBSTOR\PIONEER_BD-RW__BDR-UD03D1
USBSTOR\GenCdRom
GenCdRom
I want my BDR-UD03 crossflash to UD04. Thank you.
Post by Coopervid » Thu Aug 20, 2026 8:39 pm
ahai88 wrote: Thu Aug 20, 2026 4:24 pm Hi,
USBSTOR\GenCdRom
GenCdRom
You need to load BOTH files and you need to tick Force Flash. You didn't read the tut! Now READ and try again.
Post by Billycar11 » Thu Aug 20, 2026 9:22 pm
Revision: 1.14
Thanks again :)
see below for email
Post by Billycar11 » Thu Aug 20, 2026 9:23 pm
Device: \\.\E:
Drive Information:
Firmware Rev : 1.00
Label Code : ----
Kernel Type : ID84
Drive Capabilities:
RPC Scheme : RPC-2
Current Region : 2
see below for email
skafds
Post by skafds » Mon Aug 24, 2026 7:48 am
I have a PIONEER BD-RW BDR-UD03 and would like to be able to play my UHD Blu-ray discs on it.
Unfortunately, the drive doesn't read them. Can anyone help me with this?
EDIT: Unfortunately, I just realized that we can also send an email.
my bad sorry!
Post by Billycar11 » Mon Aug 24, 2026 1:29 pm
skafds wrote: Mon Aug 24, 2026 7:48 am Hello,
my bad sorry!
flasher sent
