Pioneer BDR-UD03 UHD possibility
mmaslar
Re: Pioneer BDR-UD03 UHD possibility
#1306 Post by mmaslar » Fri Aug 14, 2026 7:19 pm
Coopervid wrote: Fri Aug 14, 2026 6:56 pm
mmaslar wrote: Fri Aug 14, 2026 5:51 pm I'm in the same boat. Just purchased a Verbatim 43890 with Pioneer BDR-UD03 and it does not read my UHD discs.
Post your Makemkv info.
Just sent you a PM
#1307 Post by Coopervid » Fri Aug 14, 2026 7:20 pm
mmaslar wrote: Fri Aug 14, 2026 7:19 pm
Just sent you a PM
I replied.
#1308 Post by Billycar11 » Fri Aug 14, 2026 10:12 pm
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Blueastro
#1309 Post by Blueastro » Sat Aug 15, 2026 3:40 pm
I bought an internal laptop drive from AliExpress (Pioneer BDR-UD03FAL) and want to check if it is flashable for UHD and LibreDrive. If so, please let me know. Thanks in advance!
Drive Information:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.21
Serial number:
Firmware date: 2018-04-26
Firmware version: ID19
bekir59
#1310 Post by bekir59 » Sat Aug 15, 2026 5:36 pm
Just want to add another recommendation for Billy! I used his automated flasher on my Pioneer drive and the process couldn't have been easier. Literally took just a minute and my drive was fully enabled. If you need your drive sorted out, he's the guy to go to. Thanks again!
#1311 Post by Coopervid » Sun Aug 16, 2026 10:14 pm
Blueastro wrote: Sat Aug 15, 2026 3:40 pm Hi,
Drive Information:
Revision: 1.21
Serial number:
PM sent.
#1312 Post by Billycar11 » Sun Aug 16, 2026 11:05 pm
Drive Information:
Revision: 1.21
Serial number:
see below for email
notslow
#1313 Post by notslow » Mon Aug 17, 2026 6:25 pm
Hi Coopervid,
I have a Pioneer BDR-UD03 in a Verbatim 43889 and was wondering if you could provide me with the flasher for cross-flashing it to a UD04 so that it can read UHD Blu-rays.
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
Thank you very much for your help!
#1314 Post by Coopervid » Mon Aug 17, 2026 7:37 pm
notslow wrote: Mon Aug 17, 2026 6:25 pm Hi Coopervid,
Revision: 1.14
PM sent.
#1315 Post by Billycar11 » Mon Aug 17, 2026 9:43 pm
Revision: 1.14
see below for email
burgermeister
#1316 Post by burgermeister » Tue Aug 18, 2026 1:30 am
I've been using this drive for some time now with Blu-Rays and have started on the 4K UHD ones. If this drive is capable of reading them, could you please send me the firmware?
Revision: 1.03
Serial number: RGDL5-------
Firmware date: 2015-05-14
Highest AACS version: 65
Drive platform: RS8510
Firmware version: 1.03/ID19
Thank you!
Booted2777
#1317 Post by Booted2777 » Tue Aug 18, 2026 10:35 pm
Hi guys
Can this drive be modded? It's in a Verbatim 43887. Many thanks
Revision: 1.11
Serial number: TFDL311-----
Firmware date: 2018-11-28
Firmware version: 1.11
#1318 Post by Coopervid » Wed Aug 19, 2026 9:33 am
burgermeister wrote: Tue Aug 18, 2026 1:30 am Hi,
Revision: 1.03
Thank you!
PM sent.
#1319 Post by Coopervid » Wed Aug 19, 2026 9:35 am
Booted2777 wrote: Tue Aug 18, 2026 10:35 pm Hi guys
Revision: 1.11
PM sent.
#1320 Post by Billycar11 » Wed Aug 19, 2026 9:44 am
Revision: 1.11
all others email me no need to post your info here publicly just reach out to me directly
see below for email
