Ok that's what I thought. Thanks for clarifying!MartyMcNuts wrote: Mon Aug 17, 2026 2:58 am No. The Pioneer flasher is not public. Contact Billycar11
charnathan
Hi Forum,sircable wrote: Sun Aug 16, 2026 8:12 am Hi Team,
I bought a new Verbatim 43888 from eBay.
I just unboxed it and see the below details.
What do I need to do here to rip 4k discs?
Thinking of keeping this as a spare after getting one from MartyMcnuts a couple of weeks ago.
Did I get lucky or unlucky here?
It sees a 4k disc (Escape From New York) but won't rip it.
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO2P5O95943
Highest AACS version: 68
Thanks Team.
I bought exactly the same device. Would you please enlight me as well about the right procedure.
THX
Read and follow the first post in this thread to flash your drive.M0R0K0 wrote: Mon Aug 17, 2026 2:28 pmHi Forum,sircable wrote: Sun Aug 16, 2026 8:12 am Hi Team,
OS device name: F:
Revision: 1.05
Thanks Team.
THX
For sale 4K UHD Flashed USB drives:
ASUS Slim, Buffalo Slim, LG Slim,
Buffalo 5 1/4", ASUS 5 1/4",
drives@nicholasfamilycentral.com
ZU476B72N4PC
I just bought a brand new BU40N (mfd March 2026) that came with 1.05, presumably encrypted.
I reviewed the instructions in the first post many times, intending to follow the explicit instruction "BU40N on any Firmware directly to > BU40N 1.03MK". However, I was getting stuck not being able to find the 1.03 MK file for this drive. I couldn't find it in the MK set I had saved: mk-firmware-pack-20190319 or The all you need firmware pack which is linked in the first post.
Eventually I found a copy in Marty's collection All You Need Firmware Pack (MartyMcNuts). But it turns out the correct file was in The all you need firmware pack all along, it just has a different name:
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin in The all you need firmware pack is the same as the DE_LG_BU40N_1.03_MK.bin in the All You Need Firmware Pack (MartyMcNuts).
I would suggest either updating the filename in The all you need firmware pack or adding a filename instruction in the post to avoid this confusion.
No not updating the name come on man obviously 1.03 mk is thatZU476B72N4PC wrote: Mon Aug 17, 2026 8:55 pm I just bought a brand new BU40N (mfd May 2026) that came with 1.05, presumably encrypted.
That's the official name as the author made it
ZU476B72N4PC
Maybe I'm just a big dummy.Billycar11 wrote: Mon Aug 17, 2026 9:50 pmNo not updating the name come on man obviously 1.03 mk is that
Between all the various warnings about bricking a drive by using the wrong firmware, I spent a lot of time trying to find "BU40N 1.03MK" using the links and resources in the guide but was unsuccessful in finding a file so labeled.
I just acquired an ASUS SBW-06D2X-U external USB drive. MakeMKV identifies it as follows:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial number: [redacted]
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 81
I've read the first post on this thread, but it is unclear to me which firmware to flash to it. The only ASUS firmware in The all you need firmware pack is for an internal drive, and that first post says not to crossflash between LG and ASUS slim drives. How should I proceed? (My old Windows machine is basically non-responsive, so I'm trying to do this on a Mac. I've downloaded sdf.bin and am comfortable using the command line, just not sure what firmware to use. Any help much appreciated.
Manufacturer: ASUS
Revision: A102
It's far easier to say MK than it is NM00.......... so we say MK. This is why I named them MK in my firmware pack.ZU476B72N4PC wrote: Mon Aug 17, 2026 10:29 pmMaybe I'm just a big dummy.Billycar11 wrote: Mon Aug 17, 2026 9:50 pmNo not updating the name come on man obviously 1.03 mk is that
its a BU40Nluo.mai wrote: Mon Aug 17, 2026 10:42 pm I just acquired an ASUS SBW-06D2X-U external USB drive. MakeMKV identifies it as follows:
Manufacturer: ASUS
Revision: A102
follow that or email me or marty for the auto flasher
Thanks, now I've got it working.Billycar11 wrote: Tue Aug 18, 2026 2:15 am its a BU40N
Hi everyone,
I’m new here and could use some help with flashing. I have the following drive:
OS Device Name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial Number: KL5PABI0759
Firmware Date: 2020-12-02 11:14
Bus Encryption Flags: 1F
Highest AACS Version: 16
Drive Platform: MT1959
Thanks in advance for your help!
Best regards,
sfreddy
OS Device Name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Best regards,
sfreddy
Flash to WH16NS60 1.02-MK.sfreddy wrote: Tue Aug 18, 2026 5:09 pm Hi everyone,
OS Device Name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Best regards,
sfreddy
