I don't know if I should post the whole MakeMKV output for the drive model and firmware. I think these are the relevant ones: Kernel Type: ID56 / Hardware Rev: SAT 8F00
If more info is needed, tell me and I can post it. Thanks in advance.
Please post your Makemkv info with the firmware date.diron wrote: Thu Aug 06, 2026 2:38 pm Hi, I am new to the forum but have been using MakeMKV with a different drive for a while. I just bought a BD-RW BDR-212M from Japan, it works fine but the firmware seems to not be compatible with UHD. I think it can be flashed so I was hoping I could get the necessary files for this model from this forum
Drive InformationCoopervid wrote: Thu Aug 06, 2026 7:59 pmPlease post your Makemkv info with the firmware date.diron wrote: Thu Aug 06, 2026 2:38 pm Hi, I am new to the forum but have been using MakeMKV with a different drive for a while. I just bought a BD-RW BDR-212M from Japan, it works fine but the firmware seems to not be compatible with UHD. I think it can be flashed so I was hoping I could get the necessary files for this model from this forum
Only Billy can help you as this firmware is too new for the flasher.Hucz89 wrote: Mon Aug 10, 2026 3:43 amDrive InformationCoopervid wrote: Thu Aug 06, 2026 7:59 pmPlease post your Makemkv info with the firmware date.diron wrote: Thu Aug 06, 2026 2:38 pm Hi, I am new to the forum but have been using MakeMKV with a different drive for a while. I just bought a BD-RW BDR-212M from Japan, it works fine but the firmware seems to not be compatible with UHD. I think it can be flashed so I was hoping I could get the necessary files for this model from this forum
Manufacturer: PIONEER
Product: BD-RW BDR-212BK
Revision: 1.04
Serial number: <redacted>
Firmware date: 2022-12-20
Firmware version: ID81
PM sent.timk22 wrote: Thu Aug 13, 2026 10:38 am Hi,
I have a BDR-212M with the info as follows:
Product: BD-RW BDR-212M
Revision: 1.01
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: 1.01/ID56
I believe this can be flashed to read UHD BD as it has the old firmware on it, is this correct?
sure email me that info and all others email me no need to post your info here just reach out to me directlytimk22 wrote: Thu Aug 13, 2026 10:38 am Hi,
Revision: 1.01
