UHD FAQ
Re: UHD FAQ
SamuriHL wrote: Wed Aug 12, 2026 3:13 am Yea that’s all findvuk under the covers. Disc info is mine. They really don’t interact at all.
So, in your Disc Info comment, can you add the steps so people know what to do?
1. Backup to folder (leave decrypt unchecked)
2. Delete the AACS directory
3. Open index.bdmv in MakeMKV
4. Create MKV file.
nekno
Re: UHD FAQ
Post by nekno »
Copy that. So handling the return code from FindVUK could still work, but I get it if you don't want to add it for this edge case.
MartyMcNuts wrote: Wed Aug 12, 2026 4:31 am 1. Backup to folder
Backup to folder (with decrypt unchecked). That's important, or you'll be buggered right back in the same spot failing to decrypt the disc.
Explaining the workaround would save / would have saved us poor souls countless hours, but I would understand if he's reluctant to add output about another specific app (MakeMKV).
Since it's a known issue, do we know why this hasn't been prioritized to get fixed in MakeMKV (other than 'all features are unimplemented by default')?
Re: UHD FAQ
Post by SamuriHL »
MartyMcNuts wrote: Wed Aug 12, 2026 4:31 am So, in your Disc Info comment, can you add the steps so people know what to do?
4. Create MKV file.
No. :P (You'll see why shortly)
Re: UHD FAQ
Post by SamuriHL »
KeyDB Assistant v1.1.0.1 Released — New MakeMKV Folder Backup & Settings
This update adds a MakeMKV folder Backup feature and a related settings option.
What's new:
• New Backup button on the main toolbar.
• Creates a full folder backup of the inserted disc using makemkvcon64 backup.
• If a matching key exists in your KeyDB, it creates a decrypted_<DiscTitle> backup.
• If no key is found, it creates an encrypted_<DiscTitle> backup.
• Special handling for discs with a bogus AACS folder where the content is not actually encrypted: the backup is run in MakeMKV's encrypted mode to avoid corruption/failure, the output is labeled decrypted_<DiscTitle>, and the AACS directory is automatically removed afterward.
• Backup Folder Location setting added to the Settings dialog.
• Disc Info now detects non-encrypted discs and recommends using the Backup button; it also notes that the resulting folder backup can be opened directly in MakeMKV.
• Live MakeMKV output is displayed in the status window during backup.
• If a backup folder with the same name already exists, you are prompted to overwrite it.
Re: UHD FAQ
SamuriHL wrote: Wed Aug 12, 2026 3:35 pm KeyDB Assistant v1.1.0.1 Released — New MakeMKV Folder Backup & Settings
What's new:
Please provide a new link or better open a new thread that is separate from UHD FAQ. Sending people there would be much easier.
Re: UHD FAQ
Post by SamuriHL »
The link is where it always is.
viewtopic.php?f=12&t=16883&p=166510#p166510
Re: UHD FAQ
SamuriHL wrote: Wed Aug 12, 2026 9:02 pm The link is where it always is.
Thanks! It still needs a search to point users to it. A new thread "KeyDB_Assistant (with underline) would it make much easier to find. Note the underline. The search function in this forum doesn't like short key words to look for.
keydb_helper
Re: UHD FAQ
Post by keydb_helper »
Nice work on the update, those are some really neat inclusions.
Coopervid wrote: Wed Aug 12, 2026 9:31 pm Thanks! It still needs a search to point users to it. A new thread "KeyDB_Assistant (with underline) would it make much easier to find. Note the underline. The search function in this forum doesn't like short key words to look for.
I've experienced the short key word issue when searching for specific disc ID values. But I'm seeing the same results when searching for "KeyDB_Assistant" as I do when searching for "KeyDB Assistant". The search result page seems to indicate the effective query is the same:
Searched query: +KeyDB +Assistant
Public KeyDB Disc Submissions
Re: UHD FAQ
Post by SamuriHL »
keydb_helper wrote: Thu Aug 13, 2026 10:13 am Nice work on the update, those are some really neat inclusions.
Thanks, yea I thought they might prove useful. Given that my work is mostly a front end for findvuk and makemkv, scripting the backup call to makemkvcon wasn't a huge lift. The logic around dealing with unencrypted discs with bogus AACS directories was the real work behind it. But then using the decrypt backup option when you have a key in the keydb for a title was also nice to have IMO.
Felipe
Re: UHD FAQ
Post by Felipe »
Hi everyone,
I am a new user and I am looking for the custom flashing tool and firmware to cross-flash my Pioneer drive so I can rip 4K UHD discs.
Since my account is brand new, I cannot send private messages or start a new topic yet. Could an expert or seller (like Billycar11) contact me privately once my PMs are unlocked?
Here is my drive info:
- Drive platform: RS8F00
- Firmware name: PIONEER BDR-212T
- Firmware version: E115/ID71
Thank you so much for your help!
nekno
Re: UHD FAQ
Post by nekno »
What's new:
Here's some example output I got during the disc backup process:
  DISC BACKUP
Validation Data     : xxx
Media Key           : xxx
VUK                 : xxx
Unit Key 1          : xxx
Unit Key validation failed with 3 aligned units
NOTICE: Disc structure detected as not encrypted
MakeMKV encrypted backup will be used and the AACS directory will be removed afterward.
Backup mode: decrypted
Output folder: D:\decrypted_Stranger Things_ Season 4 Disc 3
MakeMKV v1.18.3 win(x64-release) started
Using LibreDrive mode (v06.3 id=xxx)
Backing up disc into folder "file://D:\decrypted_Stranger Things_ Season 4 Disc 3"
Backup done
Backup done.
Removed AACS directory from backup
Backup completed: D:\decrypted_Stranger Things_ Season 4 Disc 3
This is a nice addition, thanks. Some feedback:
Seeing "MakeMKV encrypted backup will be used" followed by "Backup mode: decrypted" makes it look like it isn't working as intended. I'm guessing the "backup mode" is about whether the key was found in the local KeyDB, and not this special case, but I wonder if it's possible to make the message clearer in this case?
Is there anyway to see more progress output from makemkvcon or there's simply no option to get more from stdout/stderr?
Not knowing what's going on, I may want to give up after some time. Any thoughts on having a Cancel button, which IIRC, could also be a useful thing for the other app functions as well?
I assume the file:// URL comes from the makemkvcon output, but the functionality that highlights the URL as a clickable link seems to expect a valid URL (e.g.,"%20" instead of spaces). I don't know if the code is tweakable to look for the closing quote, but the link is broken when spaces are included in the path.
Re: UHD FAQ
Post by SamuriHL »
I have zero control over what makemkvcon outputs, so, no none of that is going to change.
Re: UHD FAQ
Felipe wrote: Sat Aug 15, 2026 9:46 am Hi everyone,
PM sent.
boehmpa
Re: UHD FAQ
Post by boehmpa »
Hi BillyCar11,I am looking for the Auto Flash Kit / patched firmware for my external ASUS BW-16D1H-U PRO drive.MakeMKV currently shows "LibreDrive: Enabled" but "Firmware type: Original (unpatched)", so it does not recognize any 4K UHD discs yet.Here are my drive details from MakeMKV:Drive Platform: RS8F00Firmware Version: [E116/ID71 Firmware Date: 21.07.2020 Could you please provide me with the correct flash kit or files to safely patch this drive?Thank you so much for your help!Best regards,boehmpa
Re: UHD FAQ
boehmpa wrote: Mon Aug 17, 2026 9:57 pm Hi BillyCar11,I am looking for the Auto Flash Kit / patched firmware for my external ASUS BW-16D1H-U PRO drive.MakeMKV currently shows "LibreDrive: Enabled" but "Firmware type: Original (unpatched)", so it does not recognize any 4K UHD discs yet.Here are my drive details from MakeMKV:Drive Platform: RS8F00Firmware Version: [E116/ID71 Firmware Date: 21.07.2020 Could you please provide me with the correct flash kit or files to safely patch this drive?Thank you so much for your help!Best regards,boehmpa
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
