makemkv doesn't "see" the first half of first vob file (additional opening modes not availalbe)
jshohio
#1 Post by jshohio » Wed Jul 15, 2026 7:44 pm
i had this issue for the first time with makemkv. makemkv seems to have not "seen" the first half (about 500 MB) of the first vob file. the finished mkv movie simply didn't contain the first approximately 25 minutes of the movie. no error messages were given while makemkv was making the mkv file. the mkv file plays perfectly fine - it just begins about 25 minutes into the movie.
i had never had this happen before. does anyone have any ideas as to what is going on with this? tia
here is some additional information. i ran makemkv directly on the dvd (before i was working from a video ts folder that was copied onto my hdd). same issue. here is what the dialogue box says:
title #1 has a length of 10 seconds which is less than the minimum length of 120 seconds and was therefore skipped
cells 1-16 was removed from the start
title #2 was added (126 cells, 1:09:37)
operation successfully completed
my guess is that the missing first minutes of the movie is due to the cells 1-16 being removed from the start.
the movie is about 3 GB, but makemkv is making the mkv from 2.4 GB of it.
Re: makemkv doesn't "see" the first half of first vob file (additional info)
#2 Post by dcoke22 » Mon Aug 03, 2026 12:59 pm
You could try the different DVD Opening Modes to see if the outcome is different.
jshohio
#3 Post by jshohio » Wed Aug 12, 2026 1:46 pm
dcoke22 wrote: Mon Aug 03, 2026 12:59 pm You could try the different DVD Opening Modes to see if the outcome is different.
thank you for that suggestion. i'll try that.
jshohio
#4 Post by jshohio » Sun Aug 16, 2026 4:17 pm
i checked out trying to use makeMKV with different opening modes to see if i could get it to "see" my entire DVD. supposedly there are different options for opening modes available in "dvd" tab of the preferences. when i opened the preferences, there is no dvd tab. i checked all of the tabs in the preferences area and did see any options for changing the opening mode. i have version 1.18.4 (darwin arm64 release).
Sayaka
Re: makemkv doesn't "see" the first half of first vob file (additional opening modes not availalbe)
#5 Post by Sayaka » Sun Aug 16, 2026 11:02 pm
It's in View -> Preferences -> Protection -> Below "DVD" there is something called "DVD structure protection removal method", that's the drop-down menu you want. The various options should be called Auto, CellWalk, CellTrim, and CellFull.
