Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Post by Billycar11 » Fri Aug 14, 2026 10:12 pm
mmaslar wrote: Fri Aug 14, 2026 5:51 pm I'm in the same boat. Just purchased a Verbatim 43890 with Pioneer BDR-UD03 and it does not read my UHD discs.
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Blueastro
Post by Blueastro » Sat Aug 15, 2026 3:40 pm
I bought an internal laptop drive from AliExpress (Pioneer BDR-UD03FAL) and want to check if it is flashable for UHD and LibreDrive. If so, please let me know. Thanks in advance!
Drive Information:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.21
Serial number:
Firmware date: 2018-04-26
Firmware version: ID19
bekir59
Post by bekir59 » Sat Aug 15, 2026 5:36 pm
Just want to add another recommendation for Billy! I used his automated flasher on my Pioneer drive and the process couldn't have been easier. Literally took just a minute and my drive was fully enabled. If you need your drive sorted out, he's the guy to go to. Thanks again!
Post by Coopervid » Sun Aug 16, 2026 10:14 pm
Blueastro wrote: Sat Aug 15, 2026 3:40 pm Hi,
Drive Information:
Revision: 1.21
Serial number:
PM sent.
Post by Billycar11 » Sun Aug 16, 2026 11:05 pm
Drive Information:
Revision: 1.21
Serial number:
see below for email
