Need Help Installing MakeMKV on EndeavourOS (Arch Linux)
Route66Fan
Post by Route66Fan » Wed Aug 12, 2026 1:59 pm
Since I can't download MakeMKV for Linux through their website, I had to download the bin & oss files off of the Internet Archive here & here.
I tried installing it & while I could install the bin files (Using make.), I couldn't install the oss files.
How do I properly install it?
tomty89
Re: Need Help Installing MakeMKV on EndeavourOS (Arch Linux)
Post by tomty89 » Wed Aug 12, 2026 9:17 pm
Probably the same problem as seen in viewtopic.php?t=42238
TL;DR patch it yourself or wait until there's an update (hopefully there will still be one...)
DukeFleed
Post by DukeFleed » Fri Aug 14, 2026 2:05 pm
Route66Fan wrote: Wed Aug 12, 2026 1:59 pm Since I can't download MakeMKV for Linux through their website, I had to download the bin & oss files off of the Internet Archive here & here.
Hi. I use EndeavourOS too. I had to install MakeMKV via Flatpak because the AUR package no longer works with ffmpeg 9.0. The Flatpak package works perfectly; I didn't even have to re-enter my license key. Just remember to grant the necessary permissions so it can detect your optical drive—you can do this via the terminal or using Flatseal.
Sayaka
Post by Sayaka » Fri Aug 14, 2026 10:03 pm
tomty89 wrote: Wed Aug 12, 2026 9:17 pm Probably the same problem as seen in viewtopic.php?t=42238
And now there are more detailed instructions for using the patch inside that topic, too (for those who are not used to running Python scripts). :wink:
