Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
mmaslar wrote: Fri Aug 14, 2026 7:19 pm
Coopervid wrote: Fri Aug 14, 2026 6:56 pm
mmaslar wrote: Fri Aug 14, 2026 5:51 pm I'm in the same boat. Just purchased a Verbatim 43890 with Pioneer BDR-UD03 and it does not read my UHD discs.
Post your Makemkv info.
Just sent you a PM
I replied.
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Blueastro
Post by Blueastro »
I bought an internal laptop drive from AliExpress (Pioneer BDR-UD03FAL) and want to check if it is flashable for UHD and LibreDrive. If so, please let me know. Thanks in advance!
Drive Information:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.21
Serial number:
Firmware date: 2018-04-26
Firmware version: ID19
bekir59
Post by bekir59 »
Just want to add another recommendation for Billy! I used his automated flasher on my Pioneer drive and the process couldn't have been easier. Literally took just a minute and my drive was fully enabled. If you need your drive sorted out, he's the guy to go to. Thanks again!
Blueastro wrote: Sat Aug 15, 2026 3:40 pm Hi,
Drive Information:
Revision: 1.21
Serial number:
PM sent.
Drive Information:
Revision: 1.21
Serial number:
see below for email
notslow
Post by notslow »
Hi Coopervid,
I have a Pioneer BDR-UD03 in a Verbatim 43889 and was wondering if you could provide me with the flasher for cross-flashing it to a UD04 so that it can read UHD Blu-rays.
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
Thank you very much for your help!
notslow wrote: Mon Aug 17, 2026 6:25 pm Hi Coopervid,
Revision: 1.14
PM sent.
Revision: 1.14
see below for email
burgermeister
Post by burgermeister »
I've been using this drive for some time now with Blu-Rays and have started on the 4K UHD ones. If this drive is capable of reading them, could you please send me the firmware?
Revision: 1.03
Serial number: RGDL5-------
Firmware date: 2015-05-14
Highest AACS version: 65
Drive platform: RS8510
Firmware version: 1.03/ID19
Thank you!
Booted2777
Post by Booted2777 »
Hi guys
Can this drive be modded? It's in a Verbatim 43887. Many thanks
Revision: 1.11
Serial number: TFDL311-----
Firmware date: 2018-11-28
Firmware version: 1.11
burgermeister wrote: Tue Aug 18, 2026 1:30 am Hi,
Revision: 1.03
Thank you!
PM sent.
Booted2777 wrote: Tue Aug 18, 2026 10:35 pm Hi guys
Revision: 1.11
PM sent.
Revision: 1.11
all others email me no need to post your info here publicly just reach out to me directly
see below for email
Revision: 1.03
Thank you!
see below for email
flasher sent
