Public KeyDB Disc Submissions
keydb_helper
#2866 Post by keydb_helper » Thu Aug 13, 2026 10:11 am
Reveille wrote: Wed Aug 12, 2026 6:38 pm Disc type: UHD
Disc ID:866A98CB9C4E (Should've been 0x91BBAF962CFFBE7F9C12C2BCAF8F6FA56D7FB39D)
Disc dump filename:MKB20_v82_EPiC-_Elvis_Presley_in_Concert_D88C
dcom101 wrote: Wed Aug 12, 2026 7:44 pm Disc type: UHD
Disc ID: 0x627ddd91477277ed3bf10f7987bf3b913d2a627b
Disc dump filename: MKB20_v76_Speed_7719
Thanks for the submissions. Both discs have been added to the public keydb.
Reveille wrote: Wed Aug 12, 2026 11:34 pm I am very sorry I must have accidently used an account that already had access to that share when i clicked to verify it, It should be available to all now.
No worries mate, it happens all the time. Thanks for following up promptly.
Raegan wrote: Wed Aug 12, 2026 9:43 pm Disc type: UHD
Disc ID: 0xE5098B0948D29A27A2524D16613D7F9520EA9EC4
Disc dump filename: MKB20_v77_Furiosa-_A_Mad_Max_Saga_5DC7.tgz
Hey Raegan, thanks for following the submission template but unfortunately LibreDrive wasn't properly activated when creating that disc dump file. If you can power down your drive completely and try that disc again, we should be good to go with a newly created disc dump file.
If MakeMKV can actually open your disc after power cycling the drive, please create a protected backup and post a link to the discatt.dat/discattd.dat file to this thread so that your disc can be added to the public keydb.
Just to be clear, there is no need to reflash or modify the firmware on your drive in any way. Your current BU40N 1.03MK firmware is perfectly fine. Your drive encountered a transient error that resulted in the volatile LibreDrive microcode being ineffective and that is why the disc dump is incomplete.
FootFungus07
#2867 Post by FootFungus07 » Fri Aug 14, 2026 2:05 am
Forbidden Planet Arrow 4K UHD
Disc type: UHD
Disc ID: BIDDEN PLANET UHD
Disc dump filename: MKB20_v82_FORBIDDEN_PLANET_(UHD)_7B10.tgz
Drive: BD-RE BP60NB10
Drive firmware: 1.00
LibreDrive status: Enabled
Drive Link: https://drive.google.com/file/d/1JbBHsv ... drive_link
ShootTheCore
#2868 Post by ShootTheCore » Fri Aug 14, 2026 3:42 am
keydb_helper wrote: Sat Aug 08, 2026 8:21 pm
ShootTheCore wrote: Sat Aug 08, 2026 6:23 am Disc type: UHD
Disc ID: 0xC91A51AD05A1DA4A7BC26942F33D0A8F428162FE
Disc dump filename: MKB20_v76_Spaceballs_842F.tgz
Thanks for the submission ShootTheCore. Your disc has also been added to the keydb. Because the media key was already known to the public keydb, you could've processed the disc dump yourself with SamuriHL's KeyDB Assistant. Please give it a try with any future disc dump files and if the disc remains unsupported you can always submit it to this thread.
I did try use KeyDB Assistant at the time to synchronize the KeyDB file and validate the disc, but it wasn't able to do anything with the Spaceballs UHD. It just told me that it couldn't decrypt the AACS data.
Everything works fine now though with the latest KeyDB - thank you! :D
keydb_helper
#2869 Post by keydb_helper » Fri Aug 14, 2026 9:45 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v82_DISCLOSURE_DAY_7128
*MKB20_v82_FORBIDDEN_PLANET_(UHD)_7B10
*MKB20_v82_Name_of_the_Rose_UHD (0x41CF12D42352A4712EBADE464F7BA6492EC091EA)
*MKB20_v82_PRACTICAL_MAGIC_1EAA
*MKB20_v82_UNITED_93_A444
ShootTheCore wrote: Fri Aug 14, 2026 3:42 am I did try use KeyDB Assistant at the time to synchronize the KeyDB file and validate the disc, but it wasn't able to do anything with the Spaceballs UHD. It just told me that it couldn't decrypt the AACS data.
Sorry about that ShootTheCore. I think I may have misunderstood how the KeyDB Assistant tool processes partial disc dump files. Glad to hear you are all good now.
MKVDUDE
#2870 Post by MKVDUDE » Fri Aug 14, 2026 11:01 am
Another few please - All files are in the same link -https://we.tl/t-2uC3dQg6wsL4LR2y
Disc type: BD
Disc ID:e04d58a28dafded24e8bbbab6acc91e028c2499f
Disc dump filename:MKB_v82_FORBIDDEN_PLANET-_DISC_2_EXTRAS_08A6.tgz
Drive: MT1959
Drive firmware: 1.03
MKB_RO.inf link:https://we.tl/t-2uC3dQg6wsL4LR2y
Disc dump link:https://we.tl/t-2uC3dQg6wsL4LR2y
Disc type: BD
Disc ID:c5f4d23c675bfcf26185640de81864f83c1fc983
Disc dump filename:MKB_v82_Guyver_Dark_Hero_Original_Cut_9028.tgz
Drive: MT1959
Disc type: BD
Disc ID:28b47ef154edecb97ea7efadd1f8aecdac96abee
Disc dump filename:MKB_v82_Guyver_Dark_Hero_Enhanced_Version_961A.tgz
Drive: MT1959
Disc type: BD
Disc ID:b990c0435916e3a33bb4662f84653c4177658bcb
Disc dump filename:MKB_v82_Marshmallow_3ECA.tgz
Drive: MT1959
Disc type: BD
Disc ID:909082b41fd3efe15a4b20844d6559fe6641ca6b
Disc dump filename:MKB_v82_Ninja_Wars_416E.tgz
Drive: MT1959
Disc type: BD
Disc ID:6349a3ec732da3975480cf28977f14550431647f
Disc dump filename:MKB_v82_Roaring_Fire_9A76.tgz
Drive: MT1959
Many thanks!
#2871 Post by SamuriHL » Fri Aug 14, 2026 12:03 pm
keydb_helper wrote: Fri Aug 14, 2026 9:45 am
No it should have worked. If there was an MK available it should have been able to calculate the UK. The only exception would be the VID. I’m sure you know what I mean by that.
FootFungus07
#2872 Post by FootFungus07 » Fri Aug 14, 2026 2:12 pm
Hunt for the Wilderpeople 4K UHD TGZ Dump FIle
Disc type: UHD
Disc ID: Hunt for the Wilderpeople UHD
Disc dump filename: MKB20_v82_Hunt_for_the_Wilderpeople_UHD_867C.tgz
Drive Link: https://drive.google.com/file/d/1R16Mac ... drive_link
kario
#2873 Post by kario » Fri Aug 14, 2026 7:31 pm
Disc type: UHD
Disc ID: e4405eeb7c204f504f5229065ebc0c1d2003e679
Disc dump filename: MKB20_v76_Psycho_FD7B
Drive: BU40N
Did you sync the public keydb within the last 15 minutes? yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf: https://drive.proton.me/urls/9SXK4RGZ34#J7zM0S1fxGPR
Disc dump link: https://drive.proton.me/urls/974X89YZN0#ncNpKQfLsag6
Toad King
#2874 Post by Toad King » Fri Aug 14, 2026 10:01 pm
Disc type: UHD
Disc ID: FFA8BA07F13CABDD07B50404285717BA71BA8215
Disc dump filename: MKB20_v82_MacArthur_217E
Drive: BD-RW BDR-S13JX
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A
Disc dump link: https://drive.google.com/file/d/1KgFcXr ... reD-q/view
keydb_helper
#2875 Post by keydb_helper » Fri Aug 14, 2026 11:55 pm
Thanks to everyone who followed the template and provided new disc dump files. The following BD and UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB_v82_FORBIDDEN_PLANET-_DISC_2_EXTRAS_08A6
*MKB_v82_Guyver_Dark_Hero_Enhanced_Version_961A
*MKB_v82_Guyver_Dark_Hero_Original_Cut_9028
*MKB_v82_Marshmallow_3ECA
*MKB_v82_Ninja_Wars_416E
*MKB_v82_Roaring_Fire_9A76
*MKB20_v76_Psycho_FD7B
*MKB20_v77_LUPIN_3RD_CASTLE_OF_CAGLIOSTRO_28AE
*MKB20_v82_MacArthur_217E
*MKB20_v82_Hunt_for_the_Wilderpeople_UHD_867C
*MKB20_v82_Sátántangó_Part_III_84C4
*MKB20_v60_Shallows_6ED6
SamuriHL wrote: Fri Aug 14, 2026 12:03 pm No it should have worked. If there was an MK available it should have been able to calculate the UK. The only exception would be the VID. I’m sure you know what I mean by that.
Good to know my original understanding was on the right track.
The MK for that Spaceballs variant has been in the keydb since April 2025 and the VID wasn't obfuscated as the disc dump was generated with a Buffalo branded BU40N variant. The verification data in the dump file indicates that bus encryption was successfully disabled.
Is it possible that the "BUFFALO" manufacturer ID instead of "HL-DT-STBD-RE" triggered an obfuscated VID code path?
#2876 Post by SamuriHL » Sat Aug 15, 2026 1:03 am
keydb_helper wrote: Fri Aug 14, 2026 11:55 pm Good to know my original understanding was on the right track.
I don't think so. I'd have to see the log from that particular disc at the time it decided not to find the correct key. I've used that code path myself quite a few times and it's never let me down. Not really sure what could have happened there. Definitely should have worked.
