Is my UHD LibreDrive toast?
goestoeleven
I have two identical UHD flashed as follows:'
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: <redacted>
Firmware date: 2117-04-25 17:56
Highest AACS version: 82
Firmware version: 1.00
Both have been working great for 8+ months. All of a sudden, one of the drives can't seem to read anything (Blu-Ray, UHD, CD). It is picked up by the OS (Mac or Windows 11 VM), but any time I insert a disc, the drive closes, it spins for a while, and then spits the disc back out. I've ordered a lens cleaning BD disc, but I don't know if that's the issue or not.
Is this fixable?
Revision: 1.00
Is this fixable?
Re: Is my UHD LibreDrive toast?
power it off for 5 mins completely disconnected from power and usbgoestoeleven wrote: Thu Aug 13, 2026 3:43 am I have two identical UHD flashed as follows:'
Revision: 1.00
Is this fixable?
what usb case do you have just for my ongoing stat tracking of dead drives
lens cleaning discs are a joke return it
take it apart to clean it
eject tray
unplug drive with tray out
pop off front bezel clips on sides and bottom with plastic tool
undo screws from bottom will be under stickers if you have an s13, 213 does not have stickers.
flip backover and remove top cover
clean lasers with a lint free cloth or qtip and water or alcohol and dry with another do this 2 times and do not let it air dry you must remove the residue with a dry one!
goestoeleven
It's a bundled OWC Mercury USB enclosure, which I've opened up to expose an LG drive: Model BH16NS40 (Mfg date of March 2025). Label says ROM VER 1.05Billycar11 wrote: Thu Aug 13, 2026 4:02 am
eject tray
goestoeleven
I have opened the drive and cleaned the lens as suggested. Sadly, it has not changed the behavior. I reached out to OWC, and they've offered to service or replace it. Never thought I'd ask this question, but should I reflash it to stock firmware before doing so?
Won't hurt just use the official LG updater after flashing back to whatever your stock fw drive was probably a wh16ns40goestoeleven wrote: Thu Aug 13, 2026 9:45 pm I have opened the drive and cleaned the lens as suggested. Sadly, it has not changed the behavior. I reached out to OWC, and they've offered to service or replace it. Never thought I'd ask this question, but should I reflash it to stock firmware before doing so?
goestoeleven
Apologies / I used your purchased/supplied flasher to update these drives. Can you point me to where I can download the stock wh16ns40 1.05 firmware? Pulling my hair out looking for it across the forumBillycar11 wrote: Thu Aug 13, 2026 9:47 pm Won't hurt just use the official LG updater after flashing back to whatever your stock fw drive was probably a wh16ns40
viewtopic.php?t=24443goestoeleven wrote: Thu Aug 13, 2026 11:36 pmApologies / I used your purchased/supplied flasher to update these drives. Can you point me to where I can download the stock wh16ns40 1.05 firmware? Pulling my hair out looking for it across the forumBillycar11 wrote: Thu Aug 13, 2026 9:47 pm Won't hurt just use the official LG updater after flashing back to whatever your stock fw drive was probably a wh16ns40
The BH16NS40 is the 4th post.
goestoeleven
Thank you!!!MartyMcNuts wrote: Thu Aug 13, 2026 11:46 pmviewtopic.php?t=24443goestoeleven wrote: Thu Aug 13, 2026 11:36 pmApologies / I used your purchased/supplied flasher to update these drives. Can you point me to where I can download the stock wh16ns40 1.05 firmware? Pulling my hair out looking for it across the forumBillycar11 wrote: Thu Aug 13, 2026 9:47 pm Won't hurt just use the official LG updater after flashing back to whatever your stock fw drive was probably a wh16ns40
To use it you will have to flash the drive to a BH16NS40 MK version lower than 1.05 then you can use it to upgrade to original 1.05. The MK firmware pack has HL-DT-ST-BD-RE_BH16NS40-NS50-1.04-NM01701-211901041338 in the "old" folder.goestoeleven wrote: Thu Aug 13, 2026 11:57 pmThank you!!!MartyMcNuts wrote: Thu Aug 13, 2026 11:46 pmviewtopic.php?t=24443goestoeleven wrote: Thu Aug 13, 2026 11:36 pm
The other option would be to just flash it to the BH16NS40 1.05-MK from the MK firmware pack. They probably wouldn't notice any difference when you return it.
goestoeleven
couldn't get it working in a windows VM, but I was successful under MacOS. I'm good to go, and I've learned a lot. thanks again!MartyMcNuts wrote: Fri Aug 14, 2026 12:13 amTo use it you will have to flash the drive to a BH16NS40 MK version lower than 1.05 then you can use it to upgrade to original 1.05. The MK firmware pack has HL-DT-ST-BD-RE_BH16NS40-NS50-1.04-NM01701-211901041338 in the "old" folder.
eddienel10
Sounds more like a failing laser/mechanical issue than the LibreDrive flash, and if a lens-cleaning disc doesn’t help, the drive itself may be on its way out.
goestoeleven
Yup, it's an RMA return going out today.
BTW, the biggest challenge I faced trying to restore stock firmware was actually finding the download pack, as it's hosted on the nonfunctioning makemkv.com. I eventually found it in the Wayback Machine
An MK firmware pack download link has been added to this topic : viewtopic.php?p=203999#p203999BTW, the biggest challenge I faced trying to restore stock firmware was actually finding the download pack, as it's hosted on the nonfunctioning makemkv.com. I eventually found it in the Wayback Machine
Thank you for pointing this out.
