I just recently got a backup 43888 (my primary 43888 is a pioneer drive, but this new backup is an LG bu40n).
I tried flashing the backup to the bu40n mk1.03, firmware. The flash said it succeeded in the sdf tool, but then the drive shows as boot in makemkv and the sdf tool. Once it is in this state, I cannot use it to rip discs (the drive will not even open) and the sdf tool cannot flash it again, but using the LG tool I am able to reflash the original firmware, and the drive works in the sense that it can rip normal blurays, but not 4k.
Is there something I am doing wrong? I successfully flashed my old LG internal drive, but this external verbatim LG bu40n just doesn't seem to want to flash successfully.
Verbatim 43888 LG BU40N flashing failed
boguslecina
Re: Verbatim 43888 LG BU40N flashing failed
Firmware 1.0 may have problems reading and burning certain discs. Versions 1.03 and 1.05 include several fixes that improve stability, especially when burning discs.
Inferno1848
Das gleiche Problem hatte ich auch, dass mein Laufwerk sich die Schublade ebenfalls nicht mehr öffnen ließ.Btags wrote: Sat Mar 07, 2026 5:56 pm I just recently got a backup 43888 (my primary 43888 is a pioneer drive, but this new backup is an LG bu40n).
Ich konnte bei meinem Laufwerk mit der Original LG Firmware 1.05 selbst damit kein Flashen mehr durchführen, da der SVC Code nicht mehr stimmte, sehe Beitrag 8.
Welches LG Tool ist gemeint?
I had the same problem; my drive's tray wouldn't open anymore.
Even with the original LG firmware 1.05, I couldn't flash it because the SVC code was no longer valid (see post #8).
Which LG tool are you referring to?
I used the "firmware update for bu40n (version 1.05)" tool in the manuals and software tab of the following link:Inferno1848 wrote: Sun Mar 08, 2026 11:22 pmDas gleiche Problem hatte ich auch, dass mein Laufwerk sich die Schublade ebenfalls nicht mehr öffnen ließ.Btags wrote: Sat Mar 07, 2026 5:56 pm I just recently got a backup 43888 (my primary 43888 is a pioneer drive, but this new backup is an LG bu40n).
https://www.lg.com/us/support/product/lg-BU40N
Also, don't know if it will help you but after many trials I was able to Flash to the 1.04mk firmware for the bu40n and that has allowed me to rip 4ks.
Inferno1848
Also mit dem Firmware tool von LG hatte ich ebenfalls kein Erfolg gehabt, das Laufwerk ging zurück und jetzt hab ich ein neues von Verbatim und dort ist natürlich FW 1.05 drauf.
Jetzt frage ich mir nur welche Firmware ich wirklich am besten nehmen soll, aus welchem Ordner für MakeMKV und DVDFab am besten wäre, ich vermute mal wenn das Laufwerk einen defekt aufweist und man es zurück schickt das dann eine sogenannte Original Firmware drauf ist ein Vorteil ist, also das bei MakeMKV steht - Firmware type: Original (unpatched):
Aus dem All You Need Firmware Pack (MartyMcNuts)
DE_LG_BU40N_1.00.bin
DE_LG_BU40N_1.03_MK.bin
Downgrade Enabled Firmware V.2
DE_LG BU40N_1.00.bin
mk-firmware-pack-20200720 - old
HL-DT-ST-BD-RE_BU40N-1.01-RM00000-211712221221.bin
HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218.bin
mk-firmware-pack-20200720 - HL-DT-ST
BU40N-N-Main - HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin
The all you need firmware pack
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Ich möchte nur einmal ein Flash durchführen und das wars, dann pack ich kein SDFtool Flasher oder sonst ein tool mit dem Laufwerk mehr an.
Güße
Und euch allen ein angenehmen Wochenstart
So, I also had no luck with the LG firmware tool, the drive went back, and now I have a new one from Verbatim, which of course has firmware version 1.05 installed.
Now I'm just wondering which firmware I should really use, and which folder would be best for MakeMKV and DVDFab. I suspect that if the drive is defective and you send it back, having the original firmware installed is an advantage, meaning that MakeMKV says - Firmware type: Original (unpatched):
From the All You Need Firmware Pack (MartyMcNuts):
I just want to perform a flash once, and that's it. I won't touch the drive with SDFtool Flasher or any other tool again.
Greetings
And have a pleasant start to the week, everyone!
Güße
Greetings
if you want the widest compatibility go down to 1.00Inferno1848 wrote: Mon Mar 16, 2026 12:03 pm Also mit dem Firmware tool von LG hatte ich ebenfalls kein Erfolg gehabt, das Laufwerk ging zurück und jetzt hab ich ein neues von Verbatim und dort ist natürlich FW 1.05 drauf.
Ich möchte nur einmal ein Flash durchführen und das wars, dann pack ich kein SDFtool Flasher oder sonst ein tool mit dem Laufwerk mehr an.![]()
Güße
I just want to perform a flash once, and that's it. I won't touch the drive with SDFtool Flasher or any other tool again.![]()
Greetings
but you must first flash to 1.03 then go to 1.00
dont try to go to 1.00 directly it wont work
Inferno1848
Eine Verständnis Frage @Billycar11
wieso sollte man den LG BU40'N nicht direkt mit der 1.00 FW flashen?
Ich hatte es getan, es hatte ja funktioniert nur eben das mit dem zurück flashen auf 1.05 bezüglich des umtausch hatte nicht funktioniert, trotzdem war ich froh das es umgetauscht worden ist.
Irgendwie habe ich bei LG Laufwerke immer Kopfschmerzen wenn man diese mehrmals flashen soll.
Zum Beispiel habe hier ein:
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: A102
Serienummer: MO5N9400066
Firmware-Datum: 2121-06-28 13:41
Markierungen der Bus-Verschlüsselung: 1F
laut dem ein oderen anderen Beitrag soll man diesen so flashen wie ein LG BU40N,
FLashe ich dieses Laufwerk jetzt besser mit dem SDFtool flasher oder mit dem Asus mod. flasher?
Mein Ziel wäre die FW 1.00 des LG BU40N
A quick question, @Billycar11:
Why shouldn't one flash the LG BU40N directly with firmware 1.00?
I did exactly that, and it worked fine—though flashing back to 1.05 for the sake of an exchange didn't work out; still, I was glad the exchange went through.
For some reason, I always get a headache when dealing with LG drives that need to be flashed multiple times.
For example, I have this one here:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial Number: MO5N9400066
Firmware Date: 2121-06-28 13:41
Bus Encryption Flags: 1F
According to various posts, this drive should be flashed just like an LG BU40N.
Should I flash this drive using the SDFtool flasher or the Asus mod flasher?
My goal is to get the LG BU40N firmware version 1.00 onto it.
Produzent: ASUS
Revision: A102
Manufacturer: ASUS
Revision: A102
because it wont work you cant go from 2018+fw to DE fw it is impossible because of the additional downgrade checks.Inferno1848 wrote: Thu Aug 13, 2026 12:13 pm
Manufacturer: ASUS
Revision: A102
and without video evidence me and no one else will believe you went direct to 1.00 from encrypted fw
even if it were to work the good says this to keep it simple as 1.04 and 1.05 defiantly need this in my own testing
having 3 flashing methods for 1 drive is very confusing to people the less steps the better for the public every day i get complaints that flashing a bp50nb40 nb 52 is way to hard and saying the guides wrong.
Inferno1848
Glaubst du das ich dich Anlüge oder Fake News - Propaganda hier verbreite?
Was hätte ich für einen Grund?
Außerdem hätte es nicht bei der Hilfe beigetragen hier Quatsch zu verbreiten, ich brauchte ja die Hilfe und nicht xyz braucht hilfe dem einer Quatsch schreibt.
Ich habe dieses Verbatim direkt mit der FW1.00 geflasht aufgrund eines Fehler im Laufwerk, hat den DAE Test mit 0 absolviert habe ich das Laufwerk versucht mit der Original FW. 1.05 zweck Umtausch geflasht wo am ende nur das Laufwerk im Boot Modus feststeckte.
Und das ich das so gemacht habe, habe ich direkt im ersten Beitrag erwähnt.
Und hier irgendein Videobeweis zu fordern ist ja jetzt lächerlich, aber was wäre dein Einsatz?
Alle deine Tools zum flashen für die Öffentlichkeit kostenfrei zu Verfügung zu stellen?
Denke irgend jemand wird es bestimmt durchführen und dann stehst du da.
Aber wie MartyMcNuts, Coopervid es geschrieben hatten, das Laufwerk war von Anfang an defekt.
Und meine Frage wurde leider nicht beantwortet, nimmt man besser den SFD oder den Asus flasher?
Do you think I’m lying to you or spreading fake news and propaganda here?
What reason would I have for that?
Besides, spreading nonsense wouldn't have helped the situation; *I* was the one who needed help—it wasn't a case of someone writing nonsense to someone else who needed help.
I flashed this Verbatim drive directly with FW 1.00 due to a drive error; it passed the DAE test with a score of 0. I then tried flashing the drive with the original FW 1.05 for exchange purposes, but it ended up getting stuck in boot mode.
I mentioned doing exactly that in my very first post.
Demanding video proof here is ridiculous—but what would *you* be willing to put on the line?
Making all your flashing tools available to the public for free?
I'm sure someone would actually do it, and then where would you be?
But as MartyMcNuts and Coopervid wrote: the drive was defective from the start.
And unfortunately, my question wasn't answered: is it better to use the SFD flasher or the Asus flasher?
I'm not saying your lying but there are other factors at play maybe your drive was a return someone flashed it sent it back and they resold it as new I have seen that many timesInferno1848 wrote: Thu Aug 13, 2026 1:48 pm
Sure if you prove me wrong by 1 step flashing a bu40n on 1.05 original fw to 1.0 de and the drive works
ill release the pioneer downgrade firmware
video has to have no cuts
