Dumb newbie question
ANZAC
#1 Post by ANZAC » Mon Dec 08, 2025 5:27 am
OK, I ripped my first UHD, and opened the resulting mkv with VLC player.
The video was all dark green. I could hear the audio just fine.
Re: Dumb newbie question
#2 Post by dcoke22 » Tue Dec 09, 2025 5:54 am
I presume the video wasn't supposed to be dark green?
Most UHDs use a different colorspace than a regular blu-ray. If you play a UHD on equipment that doesn't know what to do with larger colorspace it often looks weird. If that's what's happening in your case, you'll have to tone map the UHD into the regular blu-ray colorspace. Here's a more detailed post about colorspaces: https://forum.makemkv.com/forum/viewtopic.php?p=163176#p163176
sazer80
#3 Post by sazer80 » Thu Aug 13, 2026 4:43 am
If it's DV then that would be the problem VLC doesn't support DV. try PotPlayer.
