Error code 525
jayman89
Error code 525
Post by jayman89 »
Is the main website down? I am getting http error 525 on all devices and browsers.
Re: Error code 525
Apparently, yes. But, we don't have control over that (only Mike does), so we can only guess.
R22D22
Re: Error code 525
Post by R22D22 »
I was wondering too for "error code 525"… :o
Best regards
Viele Grüße
R22D22
AstralWanderer
Re: Error code 525
Post by AstralWanderer »
In some cases (specifically forum thread links) this can be worked around by modifying the URL. If it is a forum thread, then the URL should start with hzzps://forum.makemkv.com/forum... (changed the "tt" to "zz" to avoid it being auto-linked) but some links go instead to hzzps://makemkv.com/forum/... (relying on subsequent redirection to go to the correct location). In this case, adding the "forum." prefix to the URL manually should bypass the error.
R22D22 wrote: Tue Aug 11, 2026 11:17 pm I was wondering too for "error code 525"… :o
Cloudflare can't connect to the site as it doesn't currently exist. For more (exciting!) details, see Error 525 · Cloudflare Support docs.
