I am a visually impaired user of MakeMKV, and I am using a Mac with VoiceOver, on the latest version of MacOS. I am unable to access the list of titles presented on an inserted DVD, which means that I can't select titles that I don't want to have imported. The interface is also a little unstable with VoiceOver, as the focus tends to jump around when I try to navigate through the window. If possible, can these issues be fixed in a future version of the program?
Also, since the website appears to be down, where can I look on the forums to make sure that my version stays up to date?
Thanks,
Rich Y.
VoiceOver Accessibility Issue
Re: VoiceOver Accessibility Issue
Current version is 1.18.4, but that's pretty much the same as all the 1.18.x versions this year.
For those who have not registered, you need to get a new key every two months, which is posted in the forum in this topic.
As a registered user, you can use any version that suits your needs; I currently have 1.16, 1.17, and 1.18 versions installed on my machines.
Sayaka
Here : viewtopic.php?t=42158R.Yamamoto wrote: Sun Aug 09, 2026 10:09 pm Also, since the website appears to be down, where can I look on the forums to make sure that my version stays up to date?
And if you just want the link to the latest version for your operating system : https://mega.nz/file/ziggWLhY#ZTkE4X3tp ... JabD6mc5Ek
