Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
brolo
Post by brolo »
Sayaka wrote: Sun Aug 02, 2026 12:19 am Private message sent, please post in this thread again if you are unable to read it, brolo.
Also :
nicholfd wrote:My understanding of Omnidrive firmware is that it does *not* change the firmware version. If your drive already had 1.02 & was patched/flashed before you received it, after flashing Omnidrive you will not see the firmware version change - Omnidrive firmware is a modified version of 1.02.
Sayaka wrote:Omnidrive is based on BU40N 1.00, no matter what the Omnidrive version is. If the firmware version is 1.02, I find it highly unlikely that this drive could have been flashed to Omnidrive (Omnidrive did change my firmware version when I flashed it on my BP55EB40s, for example).
To clarify, if your drive already has the BU40N 1.00 firmware, flashing to Omnidrive will indeed leave the firmware version unchanged even if the flash succeeds, which may have been the source of the confusion. My apologies if this was unclear.
Thanks so much! You've been super helpful. Gonna try getting down to 1.00 just for sanity's sake.
lilbit
Post by lilbit »
Are the lg bp60nb10 slims still a one step flash ? I’m sure the answer is on the forum but I’ve been reading for hours and can’t find it and am not sure how to query it in search to find the answer , thanks 🙏
nicholfd
Post by nicholfd »
lilbit wrote: Sun Aug 09, 2026 4:42 pm Are the lg bp60nb10 slims still a one step flash ? I’m sure the answer is on the forum but I’ve been reading for hours and can’t find it and am not sure how to query it in search to find the answer , thanks
First post in this very thread...
"BP60NB10 on any Firmware directly to > BP60NB10 1.02MK"
LAKingsGeek
Post by LAKingsGeek »
Several years ago I bought an ASUS BC-12D2HT but never got around to using it. I just pulled it out of it's packaging and set it up in my PC. I've been searching and browsing for definitive instructions on what I should do about flashing the firmware for UHD ripping. After much confusion I figured I'd try to rip a 4k Blu Ray, just to see what happens. I put in Jurassic Park and opened MakeMKV. It was able to read and rip the disc, no firmware flashing necessary. It's on firmware rev 3.0. Should I still flash the firmware, and if so, which one should I use? Is this a pre-encrypted firmware?
Here are the drive details:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.00
Serial number: KLZK4I81158
Firmware date: 2115-12-09 11:47
Bus encryption flags: 1E
Highest AACS version: 82
Firmware version: 3.00
BD raw metadata read: Partial
nicholfd
Post by nicholfd »
LAKingsGeek wrote: Sun Aug 09, 2026 6:58 pm Several years ago I bought an ASUS BC-12D2HT but never got around to using it. I just pulled it out of it's packaging and set it up in my PC. I've been searching and browsing for definitive instructions on what I should do about flashing the firmware for UHD ripping. After much confusion I figured I'd try to rip a 4k Blu Ray, just to see what happens. I put in Jurassic Park and opened MakeMKV. It was able to read and rip the disc, no firmware flashing necessary. It's on firmware rev 3.0. Should I still flash the firmware, and if so, which one should I use? Is this a pre-encrypted firmware?
If it ain't broke, don't fix it. If it is working for your needs, I wouldn't flash it.
swansonator1478
Post by swansonator1478 »
Hello I just bought an ASUS BW16D1X-U and it will not read 4K Blu Ray disks, the drive platform is RS8601. I have read several posts on this form and from what I have read it is possible to flash the drive but it requires a special flasher. Any assistance would be very welcome.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: RHDL029683WL
Firmware date: 2017-12-21
Highest AACS version: 61
Drive platform: RS8601
Firmware version: E111/ID76
JeremyTheGreat2
Post by JeremyTheGreat2 »
Thank you for the guide! It's satisfying being able to copy 4k movies directly to my hard drive.
Last edited by JeremyTheGreat2 on Fri Aug 14, 2026 7:43 am, edited 1 time in total.
lilbit
Post by lilbit »
nicholfd wrote: Sun Aug 09, 2026 6:54 pm
Thanks , was looking in the newest post on all the different threads , never occurred to my old feeble mind that it was still the same, I always assume things evolve , guess I should quit assuming , thanks again
sircable
Post by sircable »
Hi Team,
I bought a new Verbatim 43888 from eBay.
I just unboxed it and see the below details.
What do I need to do here to rip 4k discs?
Thinking of keeping this as a spare after getting one from MartyMcnuts a couple of weeks ago.
Did I get lucky or unlucky here?
It sees a 4k disc (Escape From New York) but won't rip it.
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO2P5O95943
Highest AACS version: 68
Thanks Team.
swansonator1478 wrote: Tue Aug 11, 2026 3:37 am Hello I just bought an ASUS BW16D1X-U and it will not read 4K Blu Ray disks, the drive platform is RS8601. I have read several posts on this form and from what I have read it is possible to flash the drive but it requires a special flasher. Any assistance would be very welcome.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
PM sent.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
flasher sent
everyone else feel free to email me for faster response
so you dont have to await forum moderator approval for your post to go up
jayw654
Post by jayw654 »
I need the flasher as well please. Asus rs8601
jayw654 wrote: Sun Aug 16, 2026 5:45 pm I need the flasher as well please. Asus rs8601
PM sent.
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
charnathan
Post by charnathan »
is there any bin files for Pioneer drives? The main post only has download links that are for LG and ASUS drives. Am I missing something?
