Public KeyDB Disc Submissions
wali187
#2836 Post by wali187 » Sat Aug 08, 2026 4:19 pm
Disc type: UHD
Disc ID: FE7A652DF2A6E382387B9EF25F8F4BF11AAC1EBE
Disc dump filename: MKB20_v82_Demon_Slayer_-Kimetsu_no_Yaiba-_The_Movie-_Mugen_Train_8BE8
Drive: PIONEER BDR-S12JX
Drive firmware: 1.01
LibreDrive status: Enabled
Did you sync the public keydb within the last 15 minutes?: Yes
Have you verified that all submission links are accessible in incognito/private browsing?: Yes
MKB_RO.inf link: https://drive.google.com/file/d/1z_DFyb ... drive_link
Disc dump link: https://drive.google.com/file/d/1YlV2tZ ... drive_link
keydb_helper
#2837 Post by keydb_helper » Sat Aug 08, 2026 8:21 pm
Chelesty wrote: Sat Aug 08, 2026 12:36 pm Disc type: UHD
Disc ID: 0x0E81F655051F94BC9821D13D72EF0ACA2F584136
Disc dump filename: MKB20_v82_THE_DRAMA_F52E.tgz
wali187 wrote: Sat Aug 08, 2026 4:19 pm Disc type: UHD
Thanks for the new disc submissions. Both have been added to the public keydb.
ShootTheCore wrote: Sat Aug 08, 2026 6:23 am Disc type: UHD
Disc ID: 0xC91A51AD05A1DA4A7BC26942F33D0A8F428162FE
Disc dump filename: MKB20_v76_Spaceballs_842F.tgz
Thanks for the submission ShootTheCore. Your disc has also been added to the keydb. Because the media key was already known to the public keydb, you could've processed the disc dump yourself with SamuriHL's KeyDB Assistant. Please give it a try with any future disc dump files and if the disc remains unsupported you can always submit it to this thread.
wabaki84 wrote: Sat Aug 08, 2026 7:06 am Thanks for the heads up, I swear this was not working for me yesterday, would've never in my life dare to waste your time on purpose, sincere appologies.
No worries mate, it happens all the time.
fizban11
#2838 Post by fizban11 » Sat Aug 08, 2026 9:27 pm
This is for the Arrow Video 4K UHD Stranger Things Complete Set
Season 2 Disc 2
Season 4 Disc 3
Season 5 Disc 2
Mods: I removed my post with .tgz for these. Researched the issue, found the workaround.
For those who cannot get these (or other) discs of the Stranger Things Arrow Video 4K UHD to rip with MakeMKV:
backup the disc, but uncheck decrypt files
once the backup is finished, open the backup folder
Delete the AACS folder
Open MakeMKV
File menu, open files
Open the backup (not the dump files)
It should open as normal for ripping the files
leftyenright
#2839 Post by leftyenright » Sun Aug 09, 2026 12:11 am
Disc type: UHD
Disc ID: 0xFF35D2608B53B3387D9C663331AEE55D121AE33D
Disc dump filename: MKB20_v82_Vampires_Kiss_UHD_F194
Drive: WH16NS40
Drive firmware: WH16NS60 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1TAM-Ow ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1RVKI3r ... sp=sharing
keydb_helper
#2840 Post by keydb_helper » Sun Aug 09, 2026 1:51 am
leftyenright wrote: Sun Aug 09, 2026 12:11 am Disc type: UHD
Thanks for following the submission template leftyenright. Your disc has been added to the public keydb.
fizban11 wrote: Sat Aug 08, 2026 9:27 pm This is for the Arrow Video 4K UHD Stranger Things Complete Set
Season 2 Disc 2
Season 4 Disc 3
Season 5 Disc 2
Hey fizban11, thanks for following the submission template but your discs have been in the public keydb for a few weeks. What you've experienced is a MakeMKV issue with processing unencrypted discs. Follow the steps listed by trashraccoon here to backup your disc.
fizban11
#2841 Post by fizban11 » Sun Aug 09, 2026 6:41 pm
Season 2 Disc 2
Season 4 Disc 3
Season 5 Disc 2
[/quote]
Edited my post above with instructions to help others looking. Appreciate it. How do people get these early and upload the volume keys weeks early...it's only been officially out for 12 days.
