LibreDrive for Pioneer drives
AxemRanger wrote: Sat Aug 08, 2026 6:30 am Feel I might have originally posted in a wrong thread. Whoops. Looking for a firmware to cross flash an XD05
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Firmware date: 2014-12-26
Highest AACS version: 82
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
PM sent.
AxemRanger
Post by AxemRanger »
Coopervid wrote: Sat Aug 08, 2026 9:45 am
Revision: 3.01
PM sent.
Much appreciated. When doing the crossflash, does that retain the burning capabilities (up to BDXL 100gb discs) or does it becoming a read only drive? Thanks again!
AxemRanger wrote: Sat Aug 08, 2026 12:58 pm
Revision: 3.01
PM sent.
Yes. No disadvantages.
Hucz89
Post by Hucz89 »
Product: BD-RW BDR-212BK
Revision: 1.04
Firmware date: 2022-12-20
Firmware version: ID81
Hucz89 wrote: Mon Aug 10, 2026 3:49 am Drive Information
Revision: 1.04
PM sent.
Revision: 1.04
Coopervid wrote: Mon Aug 10, 2026 8:08 pm
Hucz89 wrote: Mon Aug 10, 2026 3:43 am
Revision: 1.04
Serial number: <redacted>
Only Billy can help you as this firmware is too new for the flasher.
see email below
Daxxar
Post by Daxxar »
Hello everyone,
First of all, thank you for all your hard work—it is greatly appreciated.
I own this drive, and since it is an older-generation model, I was not expecting it to support LibreDrive. However, I noticed that some users have successfully enabled LibreDrive on similar models, so I would like to share my drive information below and ask whether LibreDrive support is possible for this device.
OS device name: H:
Product: BD-RW BDR-S09
Revision: 1.10
Serial number: MLDL002732WL
Firmware date: 2013-10-15
Drive platform: RS8600
Firmware version: 1.10/ID43
Daxxar wrote: Tue Aug 11, 2026 2:13 pm Hello everyone,
OS device name: H:
Revision: 1.10
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
wmr07
Post by wmr07 »
please add PIONEER BD-RW BDR-TD04. Also under win 11 pro device mgr i'm getting: STATUS_DEVICE_POWER_FAILURE This device cannot start (Code 10).
wmr07 wrote: Tue Aug 18, 2026 8:17 pm please add PIONEER BD-RW BDR-TD04. Also under win 11 pro device mgr i'm getting: STATUS_DEVICE_POWER_FAILURE This device cannot start (Code 10).
That is not a makemkv issue you have other issues maybe low power USB port or bad case hopefully not bad drive
Daxxar
Post by Daxxar »
Billycar11 wrote: Tue Aug 11, 2026 9:20 pm
OS device name: H:
Revision: 1.10
see below for email
Thanks a lot, Billy. It flashed successfully.
duopduop
Post by duopduop »
Hello, could you please help me?
I have a Pioneer optical drive – specifically, the optical drive used in the Sharp Blu-ray recorder – which was custom-made by Sharp for Pioneer.
Operating System Device Name: K:
Product: BD-RW BDR-L13SH
Revised Version: 1.18
Firmware date: 2021-01-22
Status: Feasible, but not yet enabled
Drive Platform: Pioneer RS8C00
Firmware Version: ID92
Not inserted
When playing discs with high bitrates, the playback speed is limited to approximately 2X.
The two attachments to this email include "private_data.tar" is used to manually download an SDF.bin file.Run Makemkv after Bin is launched; it will create its own executable file.The power-off and reboot operations have all been performed. Request assistance to enable LibreDrive status.
thanks very much!
babayaga
Post by babayaga »
Does anyone have these offical firmwares? I can't seem to find any old firmware for pioneer drives these days.
BDR-XD08 1.01 — checksum 93E02B4C
BDR-AD07 1.03 — checksum FFA23F11
- Babayaga
Sayaka
Post by Sayaka »
I have the one for the BDR-XD08 1.01 in official flasher form, is that enough, or are you interested only in the firmware ?
If the flasher is enough, you can download it here ("BDR-XD08B_S_G_TB_TS_TG_FW101EU") : https://mega.nz/file/mu5ykTiY#LA59dkv4I ... mhpgmVAGDg
babayaga
Post by babayaga »
Sayaka wrote: Tue Sep 08, 2026 4:33 pm I have the one for the BDR-XD08 1.01 in official flasher form, is that enough, or are you interested only in the firmware ?
Thanks, i will be needing that firmware later on i hope, so thank you! :) I have installed 1.04 on that drive unfortuenately. I flashed it with the official updater, and not all went according to plan, so trying to reflash it now with my own flasher, and it does it, but it seems only the kernel are getting through, there might be another way to attack the xd08 than the older drives. BDRFlash reports bad checksum of the 1.04 firmware, and im not sure if there are any other place to get it, or maybe a softbricked v1.01 will do the trick and let the official flasher fix the issue, would be nice to use the drive, even though not for uhd at the moment :)
