I purchased a Pioneer BDR-S11JX and had it installed. It works fine. I can't find a version of the pioneer bd drive utility that will work with this drive. I had the utility installed for the BDR-212UBK but the utility says NNo drive connected. I would like to be able to make settings chanes for the new drive but can't figure a way around this.
I am legally blind so I hope this is the correct place to post this message.
If anyone can help much thanks in advance.
Pioneer BDR-S11JX Help
Re: Pioneer BDR-S11JX Help
You could try: https://jpn-pioneer.translate.goog/ja/s ... _tr_pto=sc or https://www.touslesdrivers.com/index.ph ... code=56196Jwhitestick1 wrote: Fri Aug 07, 2026 4:28 pm I purchased a Pioneer BDR-S11JX and had it installed. It works fine. I can't find a version of the pioneer bd drive utility that will work with this drive. I had the utility installed for the BDR-212UBK but the utility says NNo drive connected. I would like to be able to make settings chanes for the new drive but can't figure a way around this.
if its a fake drive sometimes the pioneer utility wont workJwhitestick1 wrote: Fri Aug 07, 2026 4:28 pm I purchased a Pioneer BDR-S11JX and had it installed. It works fine. I can't find a version of the pioneer bd drive utility that will work with this drive. I had the utility installed for the BDR-212UBK but the utility says NNo drive connected. I would like to be able to make settings chanes for the new drive but can't figure a way around this.
and the flood of s11jx are mostly fake crossflashes
You have the wrong utility.Jwhitestick1 wrote: Fri Aug 07, 2026 4:28 pm I purchased a Pioneer BDR-S11JX and had it installed. It works fine. I can't find a version of the pioneer bd drive utility that will work with this drive. I had the utility installed for the BDR-212UBK but the utility says NNo drive connected. I would like to be able to make settings chanes for the new drive but can't figure a way around this.
Get PioneerBDR-S09-S11DriveUtility_v1.2.0.2.exe in the BDR S09 section
https://pioneer.jp/device_e/product-e/i ... iveUtility
Jwhitestick1
I downloaded the bd ddrive usility that you suggested but when i run the winrar.exe file i see: c:/users/appdata/loc
Windows is NULL
I have no idea what this means.
Can you please help me with this.
Again much thanks in advance,
J.
Windows is NULL
J.
What do you mean by winrar.exe? You should just double-click the .exe you downloaded.Jwhitestick1 wrote: Tue Aug 11, 2026 1:30 pm I downloaded the bd ddrive usility that you suggested but when i run the winrar.exe file i see: c:/users/appdata/loc
Windows is NULL
J.
